February 12, 2026, 01:51:00 AM *
Author Topic: I/S CB radio antenna: broken inside mount (solved!)  (Read 1090 times)
Savago
Brentwood - CA
« on: May 24, 2016, 07:22:09 PM »
Dear Friends
The CB radio antenna of my I/S is broken, more precisely in that inner tube that screws it in place in the mount.
Some photos:
https://goo.gl/photos/5xbeewiFcXi1N3uf7
What you guys think is the best way to repair it?
Can I order only the part that is broken? Or should I replace it for a new antenna?
Best regards
Savago
« Last Edit: June 15, 2016, 10:49:02 PM by Savago » Logged
Steel cowboy
Spring Hill, Fl.
« Reply #1 on: May 24, 2016, 08:25:19 PM »
Try Pinwall.com
2001 black interstate
2003 Jupiter Orange wing
« Reply #2 on: May 25, 2016, 08:49:12 PM »
The mount should still be good. Take it to your local communication store and see what they have for you.
If they can't do it, then look for another replacement.
I bought a GL1200 mount, and now need to get an antenna into it.
Savago
Brentwood - CA
« Reply #3 on: May 29, 2016, 03:02:11 PM »
Dear Friends
Thanks a lot for the tips, there is a CB/Ham radio near home, I will stop there and check if it can be repaired.
Savago
Savago
Brentwood - CA
« Reply #4 on: June 15, 2016, 10:48:36 PM »
An update (and adding information that might be useful for others): I visited the Radio shop and was told the antenna is an old style (30 years) and that I was pretty much hosed.
So I searched the forum and found this post:
http://www.valkyrieforum.com/bbs/index.php/topic,19368.0.html
And, guess what? This Sierra antenna is a perfect fit to the I/S. See attached some photos:
https://goo.gl/photos/kZuN37VLRtPUCQxt8
Thanks cef2lion for writing the original thread.
Savago
