February 12, 2026, 12:12:39 AM
brake retainer where does it go??
Topic: brake retainer where does it go?? (Read 870 times)
slider
mulberry arkansas
May 31, 2016, 11:26:42 AM »
Doing pumpkin service while putting back together found a piece which I finally located in book...brake pad retainer the problem is it doesn't show where it goes on the rear caliper just says make sure pads rest on the pad retainer,,,,could someone tell me where this cotton picker goes help again please..
a proud navy veteran
Re: brake retainer where does it go??
May 31, 2016, 11:44:27 AM »
You can see it here:
Your front calipers have them, they could be your guide...
WintrSol
Florissant, MO
May 31, 2016, 12:49:01 PM »
The retainer pictured in the service manual fits into the front of the caliper, and the slots on that end of the pads fit onto it; the pin being turned by Mike is at the rear, and fits through the holes in the pads on that end.
May 31, 2016, 01:03:39 PM »
Yeah, I guess that's the "SPRING, PAD" (43108-MT3-006) you
can see peeking out in my picture, not the "RETAINER"
(43112-MT3-006), I forgot there were two funny looking little
frobs in there...
WintrSol
Florissant, MO
May 31, 2016, 03:35:54 PM »
I've never taken mine off, but pretty sure it clips onto the bracket, as indicated in the parts breakdown:
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/REAR+BRAKE+CALIPER/parts.html
slider
mulberry arkansas
May 31, 2016, 07:47:57 PM »
thanks guys your info really helped,I had the spring figured out and with your help the retainer fit right in
