January 29, 2026, 06:18:35 PM *
Author Topic: help with 2002 shadow 750 ACE deluxe  (Read 1774 times)
joefromperry
Perry, OH
« on: September 24, 2009, 03:19:53 PM »
This is my last hope here; the 750 ACE board couldn't solve this, so I was hoping those of you who have helped with my Valkyrie tech problems might offer suggestions. Here's the skinny:
My 2002 Shadow ACE Deluxe has about 20,000 miles. Maintenance has been done by me regularly and all has been good. A couple weeks ago, I started down the road. The first mile was fine, as usual, but then the bike started coughing and loosing power. I managed to make it back home, but in that one mile my pipes turned blue from (I assume) a very lean condition. It had been running fine before that, and I changed nothing, including fuel.
So here's what I have done: I've replace fuel, replaced plugs (looked okay), replaced fuel filter, removed carbs and cleaned them, but the jets looked fine. I still cleaned them with gumout and blew them with air. All diaphrams look good - no tears or holes. There are no vac lines that I can find; everything looks fine. I then bypassed the fuel pump and gravity fed the carbs, and it's still the same. I can find no air leaks. So... tech geniuses on the board, any suggestions before I swallow my pride and take it to the dealer? Thanks.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: September 24, 2009, 06:18:39 PM »
Check your battery under load.
A bad battery will give you those symtoms.
Other than that it seems that your taking the proper steps to diagnose your problem.
ALWAYS QUESTION AUTHORITY!
joefromperry
Perry, OH
« Reply #2 on: September 24, 2009, 08:56:26 PM »
No, I had not checked the battery yet. I have a new battery on my Valkyrie, which is the same as the Shadow, so I'll temporarily switch them out. Thanks.
2008 Ural Patrol
TearlessTom
Spanish Fort, AL.
« Reply #3 on: September 24, 2009, 11:11:31 PM »
But what about the blue pipes. The battery wouldn't do that would it?
Tom
Blackduck
West Australia
« Reply #4 on: September 25, 2009, 12:58:43 AM »
Not familiar with the 750 but have you checked the inlet connections from the carbies to the heads?
Would also pay to check the ignition timing.
joefromperry
Perry, OH
« Reply #5 on: September 25, 2009, 01:11:08 AM »
Carbs are tightly sealed to the heads, and I plan to check the timing this weekend. Thanks.
2008 Ural Patrol
Cyclejohn
Reidsville,N.C.
« Reply #6 on: September 25, 2009, 07:31:39 AM »
Worked on a friends '01 Vulcan 750 last year that developed the same symptoms you describe. Took carbs apart (2) jets were clean, took air cutoff diaphragms out and both had sizeable holes in them (they looked as if they had melted). Replaced with new, problem diminished but not gone. Pulled petcock out, it was gunked up and and twisted. Replaced petcock with new, problem gone, bike ran like new.
