February 12, 2026, 03:41:24 AM *
Author Topic: 98 front wheel bearings on a 97  (Read 820 times)
slythern12
Fayetteville Ar.
« on: July 02, 2016, 02:55:07 PM »
I have a 97 standard and I think my front wheel bearings are going. I have talked to a friend that is VERY good with Valkyries and he says buy bearing for a 98 or above because they are better, I just want to be sure they will work ok. I just want to check and see what you guys think too. Sorry if i'm bringing up an old subject but I searched the forum and couldn't find an answer. Thanks in advance.
« Last Edit: July 02, 2016, 03:02:35 PM by slythern12 » Logged
« Reply #1 on: July 02, 2016, 03:17:10 PM »
The only difference in the 97 - 98 is the rotors that I know of. So they should work.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: July 02, 2016, 03:30:53 PM »
It's not that simple.  The front '97 bearings have an outer race diameter that is smaller than the '98.  So, the bearing cup in the wheel is smaller as well.  The '98 bearings won't fit in a '97 wheel.
That said, I've got both and front bearing wear just isn't much of an issue.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #3 on: July 02, 2016, 03:58:24 PM »
Hate to rain on your parade, but all front rotors are the same for all Valkyries.
BUT
'97 front wheel bearings are smaller outer diameter that all subsequent years, so No '98 bearings will not work
« Reply #4 on: July 02, 2016, 04:57:39 PM »
BUT
Ain't rainin on me . There you go 2funny thought I had heard they were different. Maybe the rotors wouldn't fit another year rim? Dunno but sounds like the rim is different in itself.
« Reply #5 on: July 02, 2016, 05:12:48 PM »
BUT
All front Valkyrie rotors fit all year Valkyries
