February 12, 2026, 04:08:00 AM *
Author Topic: Aftermarket bar mounted light switch.  (Read 1015 times)
F6Ghostrider VRCC #32501
Bakersfield, CA.
« on: July 06, 2016, 03:52:44 PM »
I have a 98 Tourer with two, 55 watt halogen driving lights that are wired through the high beam switch. I discovered this is a "No Go" and want/need to run them through a stand alone switch.
Can anyone recommend a clean, "Looks like OEM" product I can mount on the handlebar or some other location that does not look like something that just got slapped on in a hurry?
Any and all suggestions are appreciated.
Jeff.
« Reply #1 on: July 06, 2016, 05:04:24 PM »
These look pretty good in my opinion.  cooldude
http://www.cruisercustomizing.com/show-chrome-accessories-led-master-cylinder-switch-block-assembly-chrome-right-brake/part/BBP-52-605A?source=igodigital
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: July 06, 2016, 06:34:38 PM »
That what I use. Look for it cheaper. one wir to battery and other to key switch then all others off the switch.
Steel cowboy
Spring Hill, Fl.
« Reply #3 on: July 06, 2016, 07:37:55 PM »
I would run a relay from the battery to the lights so as not to run to much amperage thru the switch. I belive Bon S has a plug in relay that takes all the guess work out.
URL=http://s1200.photobucket.com/user/2001valkyrie/media/6C508F20-A087-4F27-860B-8B3C68291F8A_zpstvzb38qf.jpg.html][/URL]
« Last Edit: July 06, 2016, 07:48:06 PM by Steel cowboy » Logged
2001 black interstate
2003 Jupiter Orange wing
mark81
Cincinnati Ohio
« Reply #4 on: July 06, 2016, 07:47:28 PM »
Markt had a write up on how to wire the relay to your headlight
Bons makes a product called the smart switch that is basically the same thing in a neat and easy to install package
 if you look at the top of the page odds are one of their ads is up there with a link to their website markt is horse apple ranch and bons is digisync
1997 Honda Valkyrie
1981 Honda CB750 Custom
« Reply #5 on: July 06, 2016, 07:57:43 PM »
This is my favorite, Its turns my volt meter on and off
Kunkies
Charlotte, NC
« Reply #6 on: July 07, 2016, 03:58:10 AM »
I have an extra BonS smartswitch harness for driving lights if you are interested.  I hate to have it just sit here.  Let me know.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #7 on: July 07, 2016, 05:43:36 AM »
I like the Pilot kit that comes with the switch and relay. I have used it many times it is just under 30.00 and you can find them at about any pepboys auto parts store
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #8 on: July 07, 2016, 07:27:50 AM »
Kuryankyn universal driving light chrome switch and wiring harness part#2202
BobB
« Reply #9 on: July 08, 2016, 06:50:58 AM »
I have the Show Crome switch block shown below.
Power to it comes from the starter switch originally powering the headlight.  It now trips up to three relay coils.  The micro relays are inside the headlight housing.  One switch and relay turns the 55w driving lights on/off.  One relay is controlled by the high/low beam switch.  One switch and relay is for the headlight.  Yes, I can switch the headlight off which is handy at times.  The lamps are powered by a separate 20 amp fused circuit.  The third switch powers a Deer Hornet, a powered deer whistle.  There is now less than one amp passing thru that vulnerable starter switch and I no longer have problems with it...
