« on: July 11, 2016, 05:06:51 PM » |
Not my favorite repair work, but I'm getting better at it.  I've got my NTM I/S stripped down. One of the PO's must have had a issue with the trunk wiring cause the plug is missing and the wires were butt joined with those crush connectors. Crap.  I cut them out and now I want do do it up right. Any suggestions on how to continue? Should I get a used wiring harness and solder repair mine, or maybe buy after market connection(s)? I'd like to also wire her for Super Valk. Looks like I'll need the tail light and directional sub harnesses also. Suggestions and recommendations greatly appreciated. If anyone has OEM wiring for sale, let me know. Thanks.
« Reply #2 on: July 11, 2016, 06:01:32 PM » |
Bill, some of these connectors from here will work fine. http://www.cycleterminal.com/motorcycle-connectors.htmlDo you have a tail light for it already ? If so its not necessary to have a wiring harness. you can just wire it in the right side cover wiring with some bullet connectors. Rob, thanks for the info  That's what I was thinking of. I have a Standard tail light. This is what I'm dealing with.    Pretty ugly  I cut three wires to remove the trunk, I'm worried I won't have enough wire to make the connections and will have to make my own sub wire to make the length I need. Wondering if I can rewire the trunk without complete disassembly? I've already got parts of "Georgia" all over my basement.  I haven't dissected the "Super Valk" conversion post yet,
« Reply #3 on: July 11, 2016, 06:03:45 PM » |
My goal is to ride her to Oss's ride this fall.
« Reply #4 on: July 11, 2016, 06:34:03 PM » |
That will be awesome  Wiring is not my strong suit. But compared to what your PO did I look like an electrical genius  I wouldn`t worry about being short on your wire. Just solder in a nice connector with shrink tubing over it and you can make it whatever length you want. But you are definitely on the right track getting rid of all of that. I don`t remember if you pull a trailer, but if so you might want to wire in a powered harness while your at it. Looking forward to seeing her in October.
« Reply #5 on: July 11, 2016, 06:43:09 PM » |
I had bought an extra IS harness for about $25. They do come available. Also this site too, has the replacement connectors. http://www.vintageconnections.com/
eddy6
« Reply #6 on: July 11, 2016, 07:07:37 PM » |
Go to Partzilla.com. I replaced the harness from the side cover to the big plug at the fender split and the harness from fender split to tail light for like 20.00 plus shipping. Pretty reasonable for factory harness.
mark81
« Reply #7 on: July 11, 2016, 08:56:19 PM » |
I have an extra I/S rear speaker harness wont help with the lights though and those speakers do no good with a supervalk
1997 Honda Valkyrie 1981 Honda CB750 Custom
BigBad1
1999 Interstate
Garner NC
« Reply #8 on: July 11, 2016, 09:43:35 PM » |
When I added a light for the inside of trunk, I changed to a standard flat trailer connector. Very easy to plug up and unplug the one connector under the seat without taking off the side cover.
« Reply #9 on: July 12, 2016, 04:11:51 AM » |
That's a cool idea. Those connections separate pretty easily. Go to Partzilla.com. I replaced the harness from the side cover to the big plug at the fender split and the harness from fender split to tail light for like 20.00 plus shipping. Pretty reasonable for factory harness.
I looked there but it seems the wiring was obsolete . I'll look again. Rob, no trailer. Thanks for the reply's everyone.
Paladin528
« Reply #10 on: July 12, 2016, 06:57:19 AM » |
About a month ago I got the rear harness (from the side cover to the back of the forward fender piece) from Partzilla. Was pretty inexpensive as I recall. Worked out great with the Standard lighting install. I have not tackled the SuperValk mod yet.
« Reply #11 on: July 13, 2016, 03:25:34 AM » |
Where'd you find that? Every wire harness I've found is listed as "obsolete "
Paladin528
« Reply #12 on: July 13, 2016, 09:16:19 AM » |
Partzilla. Maybe I got the last one
Paladin528
« Reply #13 on: July 13, 2016, 09:18:14 AM » |
partzilla. PN 32102-MZ0-000 is the one I needed.
« Reply #14 on: July 13, 2016, 10:41:43 AM » |
Aww, there's the diff. That's a Tourer harness. I'm looking at the Interstate harness's, which Partzilla says, all are "obsolete"
NewValker
VRCC# 36356
Oxford, MA
« Reply #15 on: July 13, 2016, 05:25:59 PM » |
Hey Bill, goes without saying, if ya need help, or a look at my wiring, just ask. Craig
Turns out not what or where, but who you ride with really matters
« Reply #16 on: July 13, 2016, 05:46:13 PM » |
Craig, thanks. I figured I'd be looking closer at yours when we swap out the petcock
westsidevalk
« Reply #17 on: July 13, 2016, 06:39:33 PM » |
Bill, Dont know how I can help, but maybe I can help you track down obsolete parts. I sure am grateful for how you have helped me with my Valk. David
Paladin528
« Reply #18 on: July 14, 2016, 07:56:57 AM » |
The Tourer harness has an extra wire and a 6 place connector. it can be adapted to work with the IS if you have the other half already.
« Reply #19 on: July 14, 2016, 12:52:01 PM » |
Hey David; Thanks for the offer. I'm pretty sure when a part is listed obsolete, it means Honda doesn't have any more. I'm guessing the parts sellers, on the internet and the brick & mortar stores, don't carry many parts and just get them from Honda Distribution. Obsolete at Partzilla, than obsolete at Procalper and the local dealers. You get those bags rails straightened out?
westsidevalk
« Reply #20 on: July 16, 2016, 01:55:18 PM » |
Bill,
Bag rails are a no go. Wife finds it more difficult to get in the passenger seat. Ill run em over to you, maybe you can use them on one of your Valks. Im still amazed at how much torwue and hp I gained from bolting up my ebay supertrapps.
