csj
Peterborough Ontario Canada
« on: July 22, 2016, 09:25:59 AM » |
I'm starting the tear down of the back end of the valkyrie.
Gonna have to take off the muffler, swing arm won't go down enough.
Any warnings/pointers before I put a socket on those studs?
A guy called me a Ba$tard, I said in my case it's an accident of birth, in your case you're a self made man.
« Reply #1 on: July 22, 2016, 09:39:37 AM » |
You don't have to remove them. Remove the exhaust hanger nuts, spread the exhaust out, wedge a 1/2 inch piece of plywood in between and you will have enough room to lower the swing arm.
« Reply #2 on: July 22, 2016, 09:40:38 AM » |
I've never had one of those muffler studs give me grief.
If you remove the cap nuts and use a wood shim, the exhaust pipes will move over enough to let the swing arm down.
« Reply #3 on: July 22, 2016, 09:41:45 AM » |
« Reply #4 on: July 22, 2016, 09:49:57 AM » |
big poppa pump
« Reply #5 on: July 22, 2016, 10:04:11 AM » |
I have serviced the rear end multiple times and never had the need to touch either the exhaust or the exhaust hangers. I use a HF motorcycle/ATV lift under the engine block to raise the front only and a separate floor jack to lift the rear using the kickstand cross member. Lift the front and then the rear and remove the rear shocks. Once the shocks are removed, use the floor jack to bring down the rear (you might still not have clear access to the rear axle nut). I then slowly bring the front down on the MC/ATV lift (quick stomps on lever) till I can get clear access to the rear axle nut. Once the axle nut/rod is removed, use the floor jack to lift the rear again to get enough clearance to remove the rear tire (I always remove the lower half of the rear fender).
VRCC#35870 VRCCDS#0266 1998 Valkyrie Hot Rod
« Reply #6 on: July 22, 2016, 10:08:43 AM » |
You guys add so much WORK to an already hardish job. Just raise the swingarm and remove the axle over the top of the muffler. No need to mess with the exhaust or the rear portion of the rear fender.
csj
« Reply #7 on: July 22, 2016, 12:05:26 PM » |
Just raise the swingarm and remove the axle over the top of the muffler. I'll look to see if that can be done. The swingarm does not appear to be moving much. Probably stuck due to never having been done before. And i gotta take the pipes off so I can put new gaskets in. Old ones are pooched. I also found a front exhaust bolt broken off. Gotta be where the extra noise is coming from.
« Reply #8 on: July 22, 2016, 01:49:50 PM » |
I'll look to see if that can be done. Lol...ya well you don't have to look very hard, I do it all the time and that's how is pictured in my PowerPoint video in shoptalk...
« Reply #9 on: July 22, 2016, 02:02:50 PM » |
That's correct, on a Standard. With a Tourer or I/S, especially with bags rails, it's easier to go low.
« Reply #10 on: July 22, 2016, 02:33:04 PM » |
That's correct, on a Standard. With a Tourer or I/S, especially with bags rails, it's easier to go low. +1
