February 12, 2026, 07:39:58 AM *
Author Topic: Turn indicaters not working. SOLVED NO NEED TO CLICK, DUH ME.  (Read 823 times)
Roidfingers
Tuscaloosa, Alabama
« on: July 22, 2016, 02:03:06 PM »
Suddenly my turn indicators will not light up or flash, . Front or back. 98 std with light bar. was working on last ride. Any thoughts? Is there a fuse I need to check. Head light good. and fronts come on but not backs. Then when I turn signal to right. The front right goes out and same if I go left. But all the while no rear lights at all. Bulbs checked good on rear.
« Last Edit: July 22, 2016, 02:27:24 PM by Roidfingers » Logged
« Reply #1 on: July 22, 2016, 02:15:29 PM »
10 amp fuse in the fuse box, but it runs the horn and stop lights too.
Maybe a ground issue?
Maybe turn switch needs attention?
Roidfingers
Tuscaloosa, Alabama
« Reply #2 on: July 22, 2016, 02:26:24 PM »
Thanks Hook, wasn't sure where to look for fuse. That was it.
bentwrench
Philadelphia,Pa.
« Reply #3 on: July 22, 2016, 02:32:39 PM »
Did all the t/s stop working at the same time? It's normal for the frt. running lamps to go out during t/s op.
If the fuse is ok,pull the headlamp off and check the gray wire in the 9pin red conn.for pwr to the t/s switch.
the org and blue wires in the same conn go out to the bulbs.If it's not the fuse it's probably the t/s relay.
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: July 22, 2016, 04:07:25 PM »
What hook said.
