February 12, 2026, 07:40:20 AM *
Author Topic: Fork seals  (Read 1412 times)
Loopie
NE OH
« on: July 27, 2016, 10:29:51 AM »
Need to change the fork seals on my '99 Interstate. Specifically, which parts should I get?
Loopie
F6Dave
« Reply #1 on: July 27, 2016, 11:32:06 AM »
Honda sells a 'seal set' which includes the oil seal and dust wiper.  You could just buy the seal as it's a very common size (same as the GL-1800).  You also need 2 bottles of their SS-8 fork fluid, or an equivalent 10 weight fork oil.  That's all, though some also replace the bushings as long as you're in there.
« Reply #2 on: July 27, 2016, 04:51:26 PM »
I take it they are leaking? Have you tried the 2 methods out there first? There is the 35mm film trick and a seal tool (2 types/makes).
Seems most oil leaks are caused by debris in the seal, and the oil leaking around it. Clean the seal, and the oil leak stops.
F6Dave
« Reply #3 on: July 28, 2016, 06:04:41 AM »
Quite true, try cleaning the seal first.  I've used the Seal Doctor with great success.  It cleans better than the film trick, and is a better design than the Seal Mate.
PharmBoy
Lawton, Ok
« Reply #4 on: July 28, 2016, 06:44:37 AM »
If you do need to replace the seal (I always do both since it cost very little more) then there are a few things that you will need along with some others that make the job quicker and easier.
Valkyrie Manual (at least the parts pertaining to changing the fork seals)- Down loadable from Valkyrie Norway.
Honda seal set-(51490-MW0-003)
Honda tool (07YMA-MZ0010A)
Fork Oil
Motion Pro - Fork seal driver 45mm
                 Fork oil level tool
                 Fork seal bullet
Follow the manual step by step and most anyone can do it just as good as a pro. (pay particular attention to the way that the oil seal is installed-don't ask how I know that is important)
Hopefully, you won't need to change out the seals, but maybe this will be helpful if you do...Jim Smiley
« Last Edit: July 28, 2016, 06:47:11 AM by PharmBoy » Logged
4th Infantry Tet Vet
99 Interstate
97 Bumble Bee
97 Red & White
Loopie
NE OH
« Reply #5 on: July 28, 2016, 07:09:43 AM »
Thanks for all the replies. I've used the seal tool, and haven't had a problem for almost a year. It's starting up again (same side). The main reason I'm considering replacing is that I've lost quite a bit of oil from that side and I'm fearful it may be too low. If I have to replace the oil to get the levels right, I might as well replace the seals. Am I flawed in my thinking?
Loopie
F6Dave
« Reply #6 on: July 28, 2016, 08:39:12 AM »
If you only need to replace the seals (and maybe the bushings) but not the springs, DON'T FOLLOW THE MANUAL!  There's a much easier method that was posted here years ago.  It doesn't require complete disassembly, not even the special Honda tool.  It's much faster, and you can even do it with the forks still mounted on the bike.
The board has changed since then, but I kept a screenshot:
Relax
Power & elegance...just like the Valk
Oslo, Norway
« Reply #7 on: July 29, 2016, 10:07:34 AM »
Do you have any links , information or pics on this Seal Doctor?  How does it work?
F6Dave
« Reply #8 on: July 29, 2016, 10:38:32 AM »
Here it is:
www.riskracing.com/pages/Seal_Doctor_Page.html
It's a really great design.  It wraps around the fork tube so you can rotate it and not remove the stone guards.
Relax
Oslo, Norway
« Reply #9 on: July 30, 2016, 01:05:58 AM »
Here it is:
Tailgate Tommy
Fort Collins, Colorado
« Reply #10 on: July 31, 2016, 09:02:22 AM »
This part list is from an old post -
Fork Seal Replacement Parts List
P/N                   QTY
51412-k23-003   - 2
51414-mt7-003  -2
51415-mch-003  --- 2
51490-mwo-003 --- 2
91356-kz3-003 --- 2
Honda fork oil --- 4
Loopie
NE OH
« Reply #11 on: August 08, 2016, 08:56:56 AM »
I used this:
http://sealmate.net/
Cheap, simple and effective. And I can carry it on the bike. Takes up no space.
Loopie
« Last Edit: August 08, 2016, 09:00:02 AM by Loopie » Logged
