February 12, 2026, 07:39:49 AM
need side stand bolt clarification
Topic: need side stand bolt clarification (Read 886 times)
mark81
Cincinnati Ohio
August 11, 2016, 11:32:53 AM »
http://www.partzilla.com/parts/search/Honda/Motorcycle/1997/GL1500C%20A/SIDE%20STAND/parts.html
I have been going through my box of parts and found parts 4,5,7 should i get 3,6,8 also? From reading others posts 5 and 7 are not what fails? Is this what I should keep in my emergency parts bag or is this bolt an unlikely failure
1997 Honda Valkyrie
1981 Honda CB750 Custom
Re: need side stand bolt clarification
August 11, 2016, 11:37:51 AM »
That is the wrong page. You need to go to the frame picture, that Is the bolt (#11) that fails. The spring you mentioned (#4) doesn't fail but can be lost when the bolt its hooked to fails.
http://www.partzilla.com/parts/search/Honda/Motorcycle/1997/GL1500C+A/FRAME/parts.html
Last Edit: August 11, 2016, 11:40:20 AM by Chrisj CMA
mark81
Cincinnati Ohio
August 11, 2016, 12:23:30 PM »
Thanks Chris
1997 Honda Valkyrie
