February 12, 2026, 09:44:47 AM *
Author Topic: Clutch noise  (Read 1030 times)
harrydale
South East Missouri
« on: August 16, 2016, 07:54:18 PM »
Hello, a couple of months ago I bought a 2000 Valkyrie Interstate with 45k miles on it. So far everything seems o.k. except I have a question about a clutch noise that maybe some of you may have an idea about. When the bike is in neutral and I release the clutch lever it make a sound just like when a fan turns on a radiator. Should I be concerned or is this normal.
Thanks for you thoughts
Harrydale Smiley
« Last Edit: August 16, 2016, 08:58:15 PM by harrydale » Logged
Harrydale
2000 Interstate
« Reply #1 on: August 16, 2016, 08:48:43 PM »
It should quiet down when you pull the lever in. Not sure I am understanding what you are saying.
« Last Edit: August 16, 2016, 08:52:11 PM by Bighead » Logged
harrydale
South East Missouri
« Reply #2 on: August 16, 2016, 08:56:51 PM »
oops, I'm sorry. I wrote it wrong. Yes when in neutral and I release the clutch lever it make a sound like a radiator fan coming on. When I pull the clutch lever in the sound will quit.
Harrydale
2000 Interstate
« Reply #3 on: August 16, 2016, 09:01:42 PM »
Normal  cooldude it kind of sounds like a growling/ grinding when in neutral and when you pull the lever it stops.
Cracker Jack
« Reply #4 on: August 16, 2016, 09:49:54 PM »
What you are hearing with the clutch out/engaged and in neutral is the transmission gears turning even though it is not in gear. Pull the clutch in and it disengages the clutch and the transmission gears stop turning. This is normal and not a cause for concern. cooldude
« Last Edit: August 16, 2016, 09:52:21 PM by Cracker Jack » Logged
Memor86
Tampico, Mexico
« Reply #5 on: August 17, 2016, 08:16:24 AM »
as the guys say. when you let go the clutch lever while on neutral, the whole transmission is spining freely. BUT it should not be as loud as a radiator fan  Roll Eyes , most bikes i've had do this but again, is a quiet noise that you can barely notice
« Reply #6 on: August 17, 2016, 10:23:59 AM »
My standard 97 can be heard pretty good and has been that way since new my IS 99 can be heard but not nearly as noticeable as the standard.
harrydale
South East Missouri
« Reply #7 on: August 17, 2016, 04:26:34 PM »
Thanks for the info guys. It is appreciated.  Makes me feel a little better. I was afraid I in for some clutch work which is probably pretty expensive.
Harrydale
Harrydale
2000 Interstate
« Reply #8 on: August 17, 2016, 04:53:03 PM »
Not too expensive if Ya duz it yurself cooldude
