February 12, 2026, 09:43:59 AM *
Author Topic: Alternator install-MORE stuff learned.  (Read 1542 times)
« on: August 23, 2016, 07:36:51 PM »
Got a new alternator from Rare Electrical. Pulled out the loaner alternator that my brother supplied. On the install of the new alternator lets say it gave me a few fits and reasons to reconsider if I ACTUALLY Know what the heck I'm doing!  Roll Eyes Every time I went to level it up and attempt the reinstall it would NOT level up.  Lips Sealed So I took a long hard look at what was keeping it from going level ! When looking at the back of the alt to the left of the plug was a bolt a bit longer than the rest of them BUT it was this bolt that was hanging up on the frame inboard of the swing arm pivot. After covering the back of the alt I shortened the offending bolt. NOW the cursed alt practically fell into proper alignment.  coolsmiley Oh=B T W-that new alt-13.2 volts at idle and 14.26 around 1400 R P Ms. Those readings according to my hand dandy Harbor Freight multi meter.  cooldude Some of Y'all gonna scream blasphemy. You AIN'T sposed to alter factory equipment!  uglystupid2 BUT the alt is in it's working I'm happy and I'll ride tomorrow!  cooldude RIDE SAFE.
Roidfingers
Tuscaloosa, Alabama
« Reply #1 on: August 23, 2016, 07:44:19 PM »
pics would be awesome of that bolt
Tailgate Tommy
Fort Collins, Colorado
« Reply #2 on: August 24, 2016, 07:15:23 AM »
Hey Dennis, just pop that bad boy out and take a picture crazy2 crazy2
Gideon
Indianapolis, IN.
« Reply #3 on: August 24, 2016, 09:16:04 AM »
Good work.  cooldude
I am sure that a few of us would also have the same problem trying to figure out the answer.
« Reply #4 on: August 24, 2016, 09:41:22 AM »
2funny
« Reply #5 on: August 24, 2016, 10:06:42 AM »
             Go on ahead Tom and keep pokin at the cantankerous old fart!  2funny Ah-hell-I wuz pickin at ya when yours wuz on the lift in my brothers shop.  Roll Eyes As an aside and TOTALLY off subject lookin forward to ridin with you again to or at I-17!  cooldude RIDE SAFE.
Tailgate Tommy
« Reply #6 on: August 24, 2016, 11:56:10 AM »
I'm looking forward to it as well! Lets work out a plan when it gets closer. Maybe we can put yours on my lift this time  Grin
sixlow
St. Augustine, Fl.
« Reply #7 on: August 24, 2016, 06:10:25 PM »
next time i will trim that bolt too, it is in the back seen here on top.
also a good shot of the alt for the GW and how it needs to be re clocked a notch or two.
« Last Edit: August 24, 2016, 06:15:30 PM by sixlow » Logged
« Reply #8 on: August 24, 2016, 06:24:54 PM »
Why the zip tie on the old one ?
sixlow
St. Augustine, Fl.
« Reply #9 on: August 24, 2016, 06:28:54 PM »
The PO had it there to keep the white plug seated as the clip was broken off, it stayed till i popped the zip tie over it but replaced it with the new plug.
« Reply #10 on: August 24, 2016, 07:42:56 PM »
sixlow-the very first picture!  cooldude BEFORE I cut the bolt on my new alternator I took a close look at the one I got from my brother last year. After I had cut the bolt I called my brother and mentioned what I had done-THEN he informed me THAT'S how he was able to install it so cursed quickly last year!  tickedoff ANYWHO-learning more bout my ride-and THAT'S a good thing!  cooldude RIDE SAFE.
Roidfingers
Tuscaloosa, Alabama
« Reply #11 on: August 27, 2016, 03:38:45 PM »
Please explain this re- clock thing. I don't see anything different in pics. Looked several times. TY
sixlow
St. Augustine, Fl.
« Reply #12 on: August 27, 2016, 03:48:50 PM »
See the bolt holes the 2 on the left, (last pic) in relation to the stud for the main power connection, the GW is set up differently and accepts the new one here, Valk is the old one. There are 3 long Phillips head screws (very tight) that need to be removed and then the back rotates and nothing falls apart just spin it and put the 3 screws back in, they all line up and now it is configured for the Valkyrie set up. Easy peezy, and the screw that needs trimmed is only trimmed flush with the nut and that is all that is needed to make it slide in place.  cooldude
Roidfingers
Tuscaloosa, Alabama
« Reply #13 on: August 27, 2016, 06:03:31 PM »
So the phillips are going from about 1 oclock to 9 oclock?
pancho
Bonanza Arkansas
« Reply #14 on: August 27, 2016, 06:16:55 PM »
Look again, the back cover needs to be rotated  120 degrees clockwise.
Roidfingers
Tuscaloosa, Alabama
« Reply #15 on: August 27, 2016, 06:21:23 PM »
same as I said. right
Novavalker
99 Interstate/2017 Goldwing
« Reply #16 on: August 29, 2016, 05:46:34 AM »
Can you provide the part number for the alternator in your pictures?
http://rareelectrical.ecomm-search.com/search?SearchTerm=goldwing
BonS
Blue Springs, MO
« Reply #17 on: August 29, 2016, 06:14:02 AM »
This is the one you want.
http://www.rareelectrical.com/p-5408-new-alternator-91-00-honda-goldwing-g1500a-aspencade-31100-mt2-005-lr140-708.aspx
« Reply #18 on: August 29, 2016, 11:27:44 AM »
        YUPPERS-dats it!  Wink AND that $129.78 is to yer door!  cooldude AND a 1 Year warranty. WAY more at Honda AND Only a 90 day warranty.  Kiss RIDE SAFE.
