February 12, 2026, 09:43:53 AM *
Author Topic: I/S vs Std Shocks  (Read 1010 times)
« on: August 31, 2016, 11:19:34 AM »
Are the I/S shocks actually shorter than the STD shocks which would reduce ride height? or do they just sit lower then the STD shocks
I thought they were all the same 13" length.
I don't want any lower.
big poppa pump
San Antonio, TX
« Reply #1 on: August 31, 2016, 11:25:00 AM »
No, they are the same length. I switched out the std shocks on my yellow tourer with IS shocks.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
indybobm
Franklin, Indiana VRCC # 5258
« Reply #2 on: August 31, 2016, 12:57:23 PM »
I think that the upper chrome shell on the I/S is shorter than the STD/Tourer. Overall length is the same.
I put I/S shocks on my Tourer when one of the originals started leaking. Better shocks.
So many roads, so little time
VRCC # 5258
mark81
Cincinnati Ohio
« Reply #3 on: August 31, 2016, 06:42:04 PM »
Better shocks.
What makes them better? Do they actually make the bike sit lower likt th op said? I though they just had a stiffer spring to carry the extra weight. Wouldn't that make a lighter standard or tourer sit higher? Is the compression and rebound damping different?  Sorry for all the questions on your post 98valk but i think its relevant.
1997 Honda Valkyrie
1981 Honda CB750 Custom
indybobm
« Reply #4 on: September 01, 2016, 05:02:50 AM »
I think it felt better with the I/S shocks because when I replaced the Tourer shocks they were getting weaker. Maybe used I/S shocks equal new Tourer shocks as fair as stiffness? Anyway if your Std/Tourer shocks are on 3, you can probably put the I/S on 2. The I/S shocks have better damping. Just my opinion.
VRCC # 5258
« Reply #5 on: September 01, 2016, 02:49:48 PM »
Better shocks.
I/S have stiffer springs and rebound rates.
I have three pairs of low mileage I/S shocks and all measure 12 3/4" eye to eye on setting 1. On setting 3 they are 13". I will be comparing my STD shocks, after I pull them.
an article stated that I/S has a lower seat height than STD, this is why I'm asking and thinking the shocks are shorter. maybe it is the seat itself?
can anybody confirm STD shock length per a setting?
thanks
« Last Edit: September 05, 2016, 07:58:06 AM by 98valk (aka CA) » Logged
