January 29, 2026, 07:50:18 PM *
Author Topic: low note horn  (Read 1802 times)
csj
Peterborough Ontario Canada
« on: September 29, 2009, 12:58:12 PM »
A few days ago, I had to lean on the binders to keep a cage
from wiping me out. My wimpy stock horn would have made him
laugh even harder.
I need a good solid horn. I put a small replacement horn on my old
V65 Magna, definitely got peoples attention, but the pitch was too high.
For the Valk, I'd like to find a really low note horn, something to give
THEM a scare for a change.
I was at a big-rig accessory dealer that same day looking for a
truck horn, he had nothing of the sort.
Anbody know of a good price, low note air horn?
« Reply #1 on: September 29, 2009, 01:01:08 PM »
BigBF quad horns have two tones, and can beep people back into their own lanes even on I85 in Atlanta...
http://bigbf.com/bigbf_shop/bigbf_horns/index.htm
« Reply #2 on: September 29, 2009, 01:14:51 PM »
I use and like any of the dual horn setup out of a dodge vehicle. My present ones are from a dodge caravan, $5-10 local salvage yard. The ones from the dakotas sound even louder.
or u can go the air horn route, a lot of using the compact stebal air horn.
there are also a few articles out there that compare boat horns (low note) and auto horns (high note). I use both. low note will be heard at a further distance but is not as well heard above traffic noise close range as a high note. This is why most vehicles use a high and low note horn which together become louder. That is what I remember reading.
« Last Edit: September 29, 2009, 02:51:27 PM by CA ExhaustCoatings » Logged
« Reply #3 on: September 29, 2009, 01:51:51 PM »
An alternative to the Stebel is the Wolo BadBoy.  Same horn, different distributer.
I don't know if those are low tone enough to suit you, but they are loud enough to get someone's attention even at highway speeds.
« Reply #4 on: September 30, 2009, 09:45:02 AM »
If you go to Stebel's website, you can navigate around till you find a twin electric horn setup. I installed a set of these on a friend's Valk. They are as loud as the air horn and a lower tone too. If I replace mine, I'm going with the elctric ones. Get the part # and search for it. He bought his on the web for $35.
« Reply #5 on: September 30, 2009, 12:07:29 PM »
I use a HD horn from the Sportster horn kit. $75. Its a deep tone. It occasionally works, most of the time it sounds like a honking goose! Plus it looks good.
