February 12, 2026, 10:13:52 AM *
Author Topic: Oh yeah!  (Read 1179 times)
davit
Deerfield, WI
« on: September 05, 2016, 06:07:08 PM »
https://www.youtube.com/watch?v=IbBg6zuvppQ
Started with unmolested Standard/Tourer pipes.  I never was happy with the sound, it just didn't work for me on a hot rod bike.
Replace the stock tips with 18" truck stacks, sounded nice but a little raspy.
Added Grumpy's tips, looked great but they raised the pitch and resonated.
Cut the piggies leaving 1-1/2", sounded nice but resonated like hell.
Restored the piggies but increased the diameter to 1", using copper pipe.  Deepend the pitch and cleaned up the raspiness, and no resonating.  I am extremely pleased with the results.  Smiley
« Last Edit: September 05, 2016, 07:37:49 PM by davit » Logged
mello dude
Dayton Ohio
« Reply #1 on: September 05, 2016, 07:07:32 PM »
Nice work!  cooldude
BonS
Blue Springs, MO
« Reply #2 on: September 05, 2016, 08:03:58 PM »
The do sound good.  cooldude
« Reply #3 on: September 06, 2016, 11:28:06 AM »
Sounds good cooldude
Did you add the 1" by just going over the 1 1/2" pipe you left when you cut the piggies?
Did you sweat them on?
davit
Deerfield, WI
« Reply #4 on: September 06, 2016, 03:13:50 PM »
Thank you thank you thank you! Smiley  Although I did borrow these ideas from other threads so can't take the credit for myself.
I used a 1" x 3/4" copper reducing coupling, the 3/4" coupling is a snug fit over the piggies, then drilled and tapped for a 6-32 screw as I had in reply #10 of this thread:
http://www.valkyrieforum.com/bbs/index.php/topic,79552.0.html
Stock piggies:
« Last Edit: September 06, 2016, 03:20:52 PM by davit » Logged
« Reply #5 on: September 06, 2016, 05:02:03 PM »
Davit
Ok, so now you got me cornfussed.
Your pictures are of two different bikes, right?
davit
Deerfield, WI
« Reply #6 on: September 06, 2016, 05:16:17 PM »
No, same bike.  The last photo is after installing truck stacks, but before installing Grumpy's tips.  This setup actually sounded pretty nice with a deep growl, but was a bit raspy.
