Harryc
« on: September 07, 2016, 05:42:03 PM » |
I am installing a Kisan SignalMinder and want to convert my rear turn signals from amber to red. Ideas?
« Reply #1 on: September 07, 2016, 06:00:58 PM » |
Yes, I got a small can of Testors #1605 Transparent Red spray enamel at a local hobby shop. It's only about 3 ounces. You can often get it in the toy model section of Walmart and other similar stores. Remove your amber lenses, clean the inside good with some alcohol, just plain bathroom type, let it dry then spray the inside of the lens with 2-3 light coats of the red. Let it dry overnight, the amber lens doesn't show through. Cheaper than buying new lenses. I later replaced the bulbs with LED's for less heat.
« Reply #3 on: September 07, 2016, 07:08:51 PM » |
Also there are 2 types of lenses. The ones I linked are the 1 screw types. If you have the 2 screw type you will need to look further.
Harryc
« Reply #4 on: September 07, 2016, 08:06:08 PM » |
Thanks for the ideas. The lenses on the Tourer and Standard are the (2) screw types. I saw plenty of options on EBay and elsewhere for the (1) screw type, but not the (2). That is why I posted here.  I can find clear and smoked lenses, but not red. In fact I have smoked lenses already with red bulbs, but I'd rather have red lenses. Ideally I'd like the Kury deep dish ones but I do not believe they are made for Valk Tourers. I think Interstates use the one screw lenses if I am not mistaken.
« Last Edit: September 07, 2016, 08:11:59 PM by Harryc »
« Reply #5 on: September 07, 2016, 10:03:37 PM » |
Thanks for the ideas. The lenses on the Tourer and Standard are the (2) screw types. I saw plenty of options on EBay and elsewhere for the (1) screw type, but not the (2). That is why I posted here.  I can find clear and smoked lenses, but not red. In fact I have smoked lenses already with red bulbs, but I'd rather have red lenses. Ideally I'd like the Kury deep dish ones but I do not believe they are made for Valk Tourers. I think Interstates use the one screw lenses if I am not mistaken. I think it's '97-'98 use the 2 screw . All models '99 on use the one screw.
EddyH
2001 Standard
Lawton, Oklahoma
« Reply #6 on: September 07, 2016, 10:19:33 PM » |
I think Meathead is right. I've got a 01 Standard with the 1 screw lenses. I'm thinking the 99 and up Standards and Tourers all have the 1 screw setup. I put the Kuryakyn deep dish red lenses on the rear and really like the look.
Harryc
« Reply #7 on: September 08, 2016, 03:27:19 AM » |
Would it be simple plug and play to change out the rear signal stalks from a 99 or 00 to a 97? Direct swap?
RONNIEB
« Reply #8 on: September 08, 2016, 03:36:42 AM » |
My earlier model 99 standard used the 2 screw, same as a 07 Shadow spirit. Later model 99 and up all use single screw
1999black standard; 2000 black tourer; 1999 red/black interstate
Harryc
« Reply #9 on: September 08, 2016, 05:18:12 AM » |
This seems like a good solution. Since I have an extra set of amber lenses I am going to try it. Thanks
Ramie
« Reply #10 on: September 08, 2016, 06:59:09 AM » |
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
Harryc
« Reply #11 on: September 08, 2016, 06:11:14 PM » |
Thanks Ramie
vanagon40
« Reply #12 on: September 08, 2016, 08:32:07 PM » |
Clear Alternatives used to make two screw red lenses for the Valkyrie (and the 1100 Shadow). I do not see that they are currently available. Part number was CTS-0021-R-R.
Mr.BubblesVRCCDS0008
« Reply #13 on: September 09, 2016, 06:53:53 AM » |
You can get red lenses at advance auto parts that work great. Blazer clearance lights. Remove the center of the white plastic back with a hole saw. Drill the two holes for the plate to mount to the housing and snap lens on. If you have single bottom screw just glue white backing plate in housing with jb weld or epoxy and snap lense on. I've used these lens on several bike in the last ten years. I'll fine the part number and post it shortly.
« Reply #14 on: September 09, 2016, 08:25:13 AM » |
The lens are Blazer. B827R. 8.99 ea at autozone. You can beat their price on Amazon or eBay though
Harryc
« Reply #15 on: September 09, 2016, 08:29:50 AM » |
Thanks for the information
« Reply #16 on: September 09, 2016, 11:28:59 AM » |
Found them at tractor supply website for 2.99 each plus shipping
Harryc
« Reply #17 on: September 14, 2016, 02:16:58 PM » |
To close out this thread. I tried the Testors transparent candle apple red on the inside of the Amber lenses. My experience was that it just made them darker amber. @Ramie had it right. I tried the same on some clear lenses I had and the result was perfect. Thanks again for all of the suggestions.
« Last Edit: September 14, 2016, 02:32:53 PM by Harryc »
« Reply #18 on: September 14, 2016, 06:35:49 PM » |
HarryC, sorry about that. They do make them look darker amber but when the light came through it was red...at least on mine. Might have coated them too heavy.
Harryc
« Reply #19 on: September 14, 2016, 06:38:07 PM » |
No problem John, I appreciate the tips.
« Reply #20 on: September 14, 2016, 06:46:28 PM » |
This seems like a good solution. Since I have an extra set of amber lenses I am going to try it. Thanks I used this method, it works like a charm. Hoser
Miker
« Reply #21 on: September 16, 2016, 08:23:51 PM » |
I bought Electrical Connections kit for my I/S. It gives you red running and brake lights with amber signals, no lense change. Easy install, $50.00 +shipping. Works like a hot damn!
