February 12, 2026, 11:52:10 AM *
Author Topic: Cam Shaft Covers  (Read 907 times)
pocket aces
Tampa, Fl
« on: September 12, 2016, 02:17:21 PM »
I bought a pair of new cam shaft cover to replace my ugly old ones. Looks like an easy replacement just 2 bolts. I did notice there is a gasket behind the cover. Is there anything more to it than than the 2 bolts?
WintrSol
Florissant, MO
« Reply #1 on: September 12, 2016, 02:29:27 PM »
That's all mine has. cooldude
http://www.partzilla.com/parts/search/Honda/Motorcycle/1998/GL1500CT+A/CYLINDER+HEAD+COVER/parts.html
« Last Edit: September 12, 2016, 02:34:37 PM by WintrSol » Logged
Lyle Laun
Calgary, Ab
« Reply #2 on: September 12, 2016, 03:17:17 PM »
Simple operation to do yourself. Just take out the two bolts and pull them off. You should be able to re-use the gasket.
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
« Reply #3 on: September 12, 2016, 05:25:22 PM »
When replacing the bolts, don't over torque them.
pocket aces
Tampa, Fl
« Reply #4 on: September 14, 2016, 05:31:52 AM »
Ok Thanks!  cooldude With that gasket I was worried oil might run out after removing the cover.
WintrSol
Florissant, MO
« Reply #5 on: September 14, 2016, 08:29:59 AM »
From what I could see, the gasket is more for keeping water out than keeping oil in; there was no oil inside my covers, at all.
