February 12, 2026, 12:07:38 PM *
Author Topic: Swapping Out Rear Fender Rails  (Read 886 times)
Foozle
Lexington, KY, USA
« on: September 27, 2016, 07:11:44 PM »
Gang:
For those of you who've had to remove the rear fender rails on a Standard/Tourer- either to add an I/S trunk or install a pair of the aftermarket Cobra rails - am I correct in assuming the upper rear shock stud must be removed?
This appears to be the front-most location where the rails are attached to the frame - and it looks like a bear to break loose.  I wasn't able to locate this schematic on the fiche, so I have no idea what type of fasteners are even involved.
Any words of wisdom (or confessions based on experience)? angel
In advance, thanks kindly!
Terry
« Reply #1 on: September 27, 2016, 07:27:52 PM »
Not a bad job at all cooldude
« Reply #2 on: September 27, 2016, 08:00:31 PM »
Yes the shock mount has to come out. Do one side at a time because the fender bolts are easier to line up when the other side is in place.
« Reply #3 on: September 27, 2016, 08:08:10 PM »
They just screw out but might be rather snug since they've been there since the bike was built. And as suggested, do one side at a time. If you take everything apart first, you'll lose your religion trying to get all the bolts started again.  Wink
Foozle
Lexington, KY, USA
« Reply #4 on: September 28, 2016, 09:31:33 AM »
Thanks for the useful feedback, guys.
I completed the task this morning. Overall, it wasn't even close to the hardest things I've done.
It did take a little mass to break lose the upper shock studs; (un)fortunately, I'm amply equipped.
Terry
