January 29, 2026, 07:50:25 PM
Bike won't start
Topic: Bike won't start (Read 1680 times)
zonierascals
Bike won't start
October 02, 2009, 12:28:29 PM »
Came home and parked bike. Evrything was OK. Next day, won't start and no headlight. Seems dead. Other lights, gauges ad horn ok. Any help appreciated.
Thank's Chuck
5_19
Dublin, Texas
Re: Bike won't start
October 02, 2009, 12:51:47 PM »
Sounds like the starter switch to me.
http://www.valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
Try doing switch maintenance, worked for me.
IBA # 45723
2009 BMW R1200 GSA
Larry
Northeastern BC, Canada
October 02, 2009, 12:57:54 PM »
How about the emergency stop switch? There is a club and it is very large!
October 02, 2009, 01:53:57 PM »
Quote from: Larry on October 02, 2009, 12:57:54 PM
The headlight would still come on even if the kill was in "kill" mode
Thunderbolt
Worthington Springs FL.
I vote starter button needs maintenance
October 02, 2009, 07:18:56 PM »
Headlights run through this pitiful little switch. When it gets burned and corroded, it fails to make contact.
Larry
October 02, 2009, 10:43:37 PM »
Quote from: Chrisj CMA CR3M on October 02, 2009, 01:53:57 PM
Good point!
Reply #6 on:
October 03, 2009, 03:26:02 AM »
Kinda sounds like maybe you just left the switch on and flattened the battery.. If the kill or start switch was giving trouble the lights would still come on.. You could try charging the battery and checking all the wires for good clean connections and grounds, especially the battery negative cable at the block behind #6 cylinder..
