February 12, 2026, 02:40:50 PM
Rear Brake Pad Question
Topic: Rear Brake Pad Question (Read 1163 times)
Jruby38
Oxford Mass.
October 19, 2016, 01:11:21 PM »
Other than being a little thicker, are front and rear pads the same and interchangeable . I put new goldwing rotors and they a little thinner than stock. I think rear pad will fit because I see a lot of piston showing with new front pads.
Re: Rear Brake Pad Question
October 19, 2016, 01:16:54 PM »
Yes, they're interchangeable. The rear pads have the stainless insulator on them which is transferable.
Jruby38
Oxford Mass.
October 19, 2016, 03:22:52 PM »
Thanks Rick-D. Do you know of I should ditch the insulator on the front?
October 19, 2016, 05:23:59 PM »
I switched to Wing rotors with no pad change. No problems yet. 3-4 years now.
Lyle Laun
Calgary, Ab
October 19, 2016, 06:46:24 PM »
Don't mean to hijack this thread but.....what year of wing rotors fit ?
Lyle..
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
October 19, 2016, 07:52:16 PM »
Quote from: Lyle Laun on October 19, 2016, 06:46:24 PM
Lyle..
there are other rotors that work, cb600 for one and are cheaper than the wing ones.
the valkyrie OEM rotors are thicker than any other rotors honda has put on any other bikes.
Reply #6 on:
October 20, 2016, 07:20:20 AM »
Quote from: Jruby38 on October 19, 2016, 03:22:52 PM
Yea, you can. They may not fit if the insulator stays, besides, there's not the heat buildup like there is on the rear so the insulator is not necessary.
