December 31, 2025, 12:56:21 PM *
Author Topic: Does anyone have a loose kickstand that Bangs when you are riding?  (Read 1460 times)
Bassfisher
Central Arkansas
« on: October 20, 2016, 06:00:19 AM »
Does anyone have a kickstand that bangs against their pipes/or frame when they are riding.  I tightened the retaining bolts but Im still getting an bang when I hit a bump on the road. THe spring seems tight with no slack.  Any solution?
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: October 20, 2016, 07:40:33 AM »
Check the crossmember that the sidestand bolts to. The crossmember might be bent which changes the position of the sidestand.
So many roads, so little time
VRCC # 5258
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: October 20, 2016, 07:47:35 AM »
Maybe the spring seems tight but is weak enough to allow it to bang.  I'd replace it and keep the old one as a spare, if you have not experienced the joy of a broken kickstand spring you can't really appreciate why you would want a spare.
Kep
My "Mid-life Crisis "
Indiana
« Reply #3 on: October 20, 2016, 07:49:11 AM »
I'm not a Doctor...but it sounds like you need to see one...right away !
Lyle Laun
Calgary, Ab
« Reply #4 on: October 20, 2016, 04:57:58 PM »
Are you sure it's the kickstand hitting ? May be missing nuts on the rear muffler hangers. You can also get a similar sound from a bad rear wheel bearing going bad.
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
valkyriemc
NE Florida
« Reply #5 on: October 25, 2016, 04:12:51 AM »
You got that right. Or figure a way to keep that k stand tucked up when you ride home..
Veteran USN '70-'76
Bassfisher
Central Arkansas
« Reply #6 on: October 25, 2016, 04:52:47 AM »
New one is on order, hopefully here in the next couple days.
indybobm
« Reply #7 on: October 25, 2016, 05:44:54 AM »
Not many people have had a side stand spring fail. It is usually the 'Spring Hook' that the other end of the spring attaches to. It is Item #11 on the frame fiche. They bend and then break off.
Did you check the crossmember?
http://www.procaliber.com/oemparts/a/hon/5054120ff870021c54bee67c/frame
VRCC # 5258
Bone
« Reply #8 on: October 25, 2016, 07:46:15 AM »
Soon after I bought my Valk stopped to get gas and the sidestand went limp as I lowered the stand.
Turned out #11 on the fiche was bent I didn't lose the spring but the bolt was useless. At home I pushed
the Sears lift slowly under the bike. I discovered I bent the bolt with the lift pushing it to far under
the bike. I have cut a piece of 2x4 that I put at the foot of the stand that stops the lift before it touches the bolt.
Keep the spacer on the jack it would get lost.
falconbrother
« Reply #9 on: October 25, 2016, 10:53:51 AM »
I bought a tire at a local Honda dealer and they broke #11 for me...turkeys.  I discovered it up on the BLue Ridge parkway when the stand started dragging the pavement.  If you find a Honda motorcycle dealer with a good mechanic stay with it.  They are hard to find.
« Reply #10 on: June 08, 2019, 11:26:12 AM »
Mine started drooping today. If I attach a bungee cord to it the cord touches my truck stack when the kickstand is up.
Suggestions.
« Reply #11 on: June 08, 2019, 02:47:40 PM »
Ride it like you stole it until you can fix it.  coolsmiley
« Reply #12 on: June 09, 2019, 09:20:44 AM »
Had to ride to Walgreens for stronger different anti congestion meds. Kickstand went into full droop mode.  Rode in 3rd holding it up with left heel. Pulled back into Super 8 parking lot and there's the spring on the ground in my parking space!
