February 12, 2026, 06:40:49 PM *
Author Topic: I/S put together.  (Read 1218 times)
« on: October 21, 2016, 10:50:42 AM »
Getting ready to reassemble my Interstate fairing.  Took it apart last spring to fix a number of crap the PO did.  I actually found a wood screw in the light bulb mounting area where the spring should be, along with the JBWeld.  Guess he didn't have a lot of faith in the JB.  crazy2 uglystupid2
Anyways, was wondering if someone with more experience could give the correct way to proceed.  What goes on first, fairing or instrument panel?  (What goes on first, Who goes on second?) there, I said it before any OTHER wiseass does.
Does the windshield need to go one before the fairing is installed?
Any other tips will be appreciated.
Just trying to save myself having to do it twice or thrice.
Thanks ahead.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #1 on: October 21, 2016, 12:56:14 PM »
It is covered a little in Section 2 of the Service Manual. I do not know how much help that will be, it is not very detailed. It has disassembly instructions with assembly being the reverse of that. It might help with the sequence.
« Last Edit: October 21, 2016, 12:58:40 PM by indybobm » Logged
So many roads, so little time
VRCC # 5258
NewValker
VRCC# 36356
Oxford, MA
« Reply #2 on: October 21, 2016, 02:07:13 PM »
Ain't much help Bill, but I changed my windshield with the fairing intact. Just had to take off the chrome piece and speaker pods to get to it. So, pretty sure that can wait to go on.
Craig
Turns out not what or where,
« Reply #3 on: October 21, 2016, 02:53:36 PM »
I keep forgetting to look at that, good advice, thanks.
Craig
Actually, thats good to know, thanks Craig.
larue
Clermont,FL
« Reply #4 on: October 21, 2016, 06:26:11 PM »
Assuming the blinkers are installed along with the headlight assembly and it's bezel, Secure the fairing shell first with four aluminum washer inserts and then drive in the bolts, then lay the fairing rubber protective that's secured to the fairing with double sided tape at the each corner,then windshield with rubber grommets inserted, then secure the chrome trim with screws from the inside, then, hook the wires on the speaker panels to the male and female counterparts in the fairing, turn on the radio make sure they're working before securing them, if the little brass inserts are out plz jb weld them in first then anti seize the screws and just snug the speakers panels back in , Do Not Overtight those or you're back to square one.
« Last Edit: October 21, 2016, 07:44:38 PM by larue » Logged
Dusty
Mill Bay B.C.
« Reply #5 on: October 21, 2016, 07:24:44 PM »
I don't think it's a good idea to lock tite any fairing screws as earlier suggested. As someone said earlier Fairing shell with headlight and trim and the blinkers.  Bolt to the frame
Dusty
larue
Clermont,FL
« Reply #6 on: October 21, 2016, 07:45:14 PM »
Sorry corrected! I meant anti seize Smiley
Firefighter
Harlingen, Texas
« Reply #7 on: October 22, 2016, 05:35:16 PM »
The instrument panel goes on before the fairing. The fairing mounts with 2 screws at the windshield mounting area (rearward), two bolts at the outside edges of the fairing up high on the fairing (forward facing), two bolts that also hold the turn signals straight, thats all.
The windshield is next with four bolts (rearward).
The chrome cover is next and mounts with 4 bolts (foward facing) inside the fairing.
The speakers pods are last, plug in the speakers, and each one mounts with 4 bolts.
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Dusty
Mill Bay B.C.
« Reply #8 on: October 22, 2016, 06:15:23 PM »
Loctite   Shocked Shocked Shocked    anti seize   cooldude cooldude cooldude
Dusty
« Reply #9 on: October 26, 2016, 03:55:03 PM »
Hey Larue and Firefighter, thanks for the responses. cooldude cooldude
larue
Clermont,FL
« Reply #10 on: October 27, 2016, 09:03:32 PM »
Glad I could help
