February 12, 2026, 06:40:26 PM *
Author Topic: Squeal when in reverse..  (Read 1562 times)
Gogego
Id get closer, but the bumps would show
Illinois
« on: November 09, 2016, 06:21:27 PM »
This sound seems to happen when the bike is cold but I hear it while walking it back
What might be causing this sound. It is hard for me to say if there is greater resistance backing up as it is a new feel to me.
CHEERS
People who h8 people, come together!   -Bill Hicks-
2000 Valkyrie I/S
2002 Shadow Sabre
« Reply #1 on: November 09, 2016, 08:01:34 PM »
Rear brake sticking? RIDE SAFE.
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #2 on: November 10, 2016, 06:47:55 AM »
Maybe it's you squealing in joy at the thought of riding your Valk?   Evil
I'm familiar with the sensation....  cooldude
Tfrank59
'98 Tourer
Western Washington
« Reply #3 on: November 10, 2016, 10:29:58 AM »
you think it's drivetrain or brakes?  my front brakes do that when cold and I'm pushing her back out of the garage, but ain't nothin to it. But if it's your rear drive, well I'd get her on a lift and check on that.  maybe it's not the drive but the rear brake (left side), in which case I'd say don't worry.
-Tom
Gogego
Illinois
« Reply #4 on: November 10, 2016, 04:14:47 PM »
I will keep paying attention, but it might just be a strange sounde
of joy escaping me as I get ready to ride
CHEERS
2000 Valkyrie I/S
2002 Shadow Sabre
phideux
« Reply #5 on: November 11, 2016, 05:57:53 AM »
Mine squeals when I back it out of the shed, with mine it is a front brake rubbing.
pancho
Bonanza Arkansas
« Reply #6 on: November 12, 2016, 07:55:06 AM »
Sounds like you guys might need to remove the calipers, push the pistons out a bit, and clean them up.....  the brake dust and debris may be starting to make them hang up.
ETC
« Reply #7 on: November 12, 2016, 01:35:37 PM »
Mine doesn't squeal but does at times voice some growling and low pitch rear brake noise. It only does it when cold so I just ignore it. I am guessing this is the problem with yours also.
Michvalk
Remus, Mi
« Reply #8 on: November 12, 2016, 02:00:52 PM »
It could also be a bad rear bearing cooldude
Gogego
Illinois
« Reply #9 on: November 12, 2016, 03:32:49 PM »
It is on the cold side, low 40s, but once I ride for a bit I don't hear it when I stop for fuel or whatever. Seems to be only happening when cold starting.
CHEERS
2000 Valkyrie I/S
2002 Shadow Sabre
pancho
Bonanza Arkansas
« Reply #10 on: November 12, 2016, 03:52:51 PM »
It will only get worse,, eventually you will notice hat the bike is HARD to move backward when it is cold.  Not hard to take care of, just takes some time.
ETC
« Reply #11 on: November 12, 2016, 05:18:57 PM »
It's not a bearing it's in the brake caliper and most likely just the pads. I would play it by ear and see as I doubt it will get worse and probably go away with the next pad change.
« Reply #12 on: November 13, 2016, 10:47:51 AM »
Get a water sprayer and wet it down prior to moving the bike. If that will stop the noise, then there is no problem and like others have said, it's simply the pads rubbing on the rotor.
ETC
« Reply #13 on: November 13, 2016, 01:50:34 PM »
Or perhaps you backed over a pig  Roll Eyes
WintrSol
Florissant, MO
« Reply #14 on: November 16, 2016, 08:55:22 AM »
2funny Funny, as the thread is about sound.
Gogego
Illinois
« Reply #15 on: November 17, 2016, 07:18:44 PM »
We had 70 degree weather today and I had no squeal, I just have to keep in mind the use this bike has seen so there are some creaky joints when it is cold, or humid, or too cloudy, or too sunny...... laugh
CHEERS
2000 Valkyrie I/S
2002 Shadow Sabre
« Reply #16 on: November 17, 2016, 07:32:43 PM »
Sounds like me.  Wink
