November 20, 2025, 07:04:38 AM *
Author Topic: Pinion cup  (Read 1860 times)
paul
« on: October 04, 2009, 05:12:29 PM »
Hey,,
Who knows the pinion cup nut size off hand???going to break it down tommowow and clean er up...Raining here in TX all week...T.I.A. Wink
PatrickDoss
Alabama
« Reply #1 on: October 04, 2009, 08:23:58 PM »
If I remember right, I used a 7/8".  But it's been a while.
Dino
Fort Worth Texas.
« Reply #2 on: October 04, 2009, 09:26:02 PM »
It is a 22 mm.I had to buy one last night at Advance Auto to change my pinion cup. Got it in 1/2 '' drive,and removed it with an air impact wrench.Came right off ,no problem.
So many roads.....They won't ride themselves!
MP
North Dakota
« Reply #3 on: October 05, 2009, 04:56:25 AM »
We got a New Holland combine back in the 70's made in Belgium.  It was metric, and of course we had NO metric wrenches back then.  Had to buy them up to the eq. of 9/16's.  After that, the larger sizes are so close to our sizes, we just used regular wrenches.  They work fine.
MP
"Ridin' with Cycho"
humshark
Spring Hill Tennessee
« Reply #4 on: October 05, 2009, 06:58:15 AM »
You can use the standard size wrenches and sockets on the larger size but I prefer to use the 6 sided sockets as opposed to the twelve when doing so.
I have been filling out my metric large sizes over the past few years and just picked up the 27mm for the rear axle nut!  Prior to that 1 1/8th worked.
99 Interstate
05 FJR
97 Vulcan '88' Hacked
paul
« Reply #5 on: October 05, 2009, 12:53:27 PM »
Thanks,,going past china frieght tommorow/willl stop and grab a 22mm socket...the manual says 16mm threads so i was guessing it would be in the 20,s for the nut...my drive shaft teeth corners / edges are rounded off so replaceing it and the cup.2001  38k miles...dont think prev. owner was much on preventive maint.
Daniel Meyer
The State of confusion.
« Reply #6 on: October 05, 2009, 07:39:36 PM »
If you are replacing the cup, replace the shaft as well. A worn-into-new part will rapidly wear the new one to as bad as the old.
Shaft and cup need to be replaced together.
CUAgain,
Daniel Meyer
paul
« Reply #7 on: October 06, 2009, 02:32:53 PM »
Thanks Daniel,,have them both on order with wheel bearing,,the wheel hub spline, and gear look good.Was going to just replace the shaft till I saw your post on changing the pinion cup also..
