February 12, 2026, 06:40:29 PM
Rear End Assembly
Topic: Rear End Assembly (Read 1367 times)
97BLKVALK
VRCC#26021
Detroit Lakes, MN
Rear End Assembly
November 14, 2016, 07:06:42 PM »
Hello,
I'm getting ready to assemble the rear drive assembly and was curious what type of sealant to use when putting the hub cover back on.
Thanks in advance for your help.
And if you have rear end jokes, of course entertain us.
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
Re: Rear End Assembly
November 14, 2016, 07:28:51 PM »
Are you rebuilding your Final Drive or just installing the Final Drive and Rear Wheel?
If the latter, this will help.
http://www.valkyrieriders.com/shoptalk/rear_end_service.pptx
97BLKVALK
VRCC#26021
Detroit Lakes, MN
November 15, 2016, 06:57:42 AM »
Quote from: Hook#3287 on November 14, 2016, 07:28:51 PM
Rebuilding final drive.
November 15, 2016, 07:31:24 AM »
Quote from: 97BLKVALK on November 15, 2016, 06:57:42 AM
I used "Ultra Black Permatex"... some others talked about Ultra Gray...
November 15, 2016, 07:52:07 AM »
I just stopped at a local Yamaha shop and picked up a tube of I think it's called "Yamaseal" or something like that. It's also gray, when applying be careful as to not cover certain holes on the matching surfaces. The shop manual will tell you which ones.
97BLKVALK
VRCC#26021
Detroit Lakes, MN
November 15, 2016, 12:36:13 PM »
Thanks.
Harryc
Sebastian, Fl
Reply #6 on:
November 15, 2016, 02:32:53 PM »
I use Hondabond. Great stuff, and is resistant to everything. Was probably what was used originally. Get it at your local Honda dealer.
Last Edit: November 15, 2016, 02:36:22 PM by Harryc
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
