March 15, 2026, 08:26:53 AM *
Author Topic: Used part 18417-MCA-A20 for centerstand install?  (Read 2751 times)
Scottsscooter
« on: January 01, 2017, 03:19:28 AM »
I have been watching ebay, and so far no luck on any used exhaust heat shield, part number 18417-MCA-A20.          Any other experiences out there who else to check with? Thanks,
Happy New Year.........
Scott
GA VALK
« Reply #1 on: January 01, 2017, 05:08:37 AM »
Check with Jimmy at Torq Master-  www.torqmasterpipes.com/
951-443-6464
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #2 on: January 01, 2017, 08:21:12 AM »
You can cut the tin for clearance and use it till you find a good deal on a replacement. Once you find one the old piece will never get used again anyway, prolly has no value. Check with trike shops though, your part may have more value than the one you need. They must remove the center stand to install the trike kit. Maybe you can find all needed parts there.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
bscrive
Ottawa, Ontario
« Reply #3 on: January 01, 2017, 08:51:12 AM »
I got a list of motorcycle wreckers in the states and called each one until I found someone who had one.
UPDATE:
I found mine at this motorcycle salvage place in Michigan.
http://www.michiganmotorcyclesalvage.com
« Last Edit: January 01, 2017, 01:25:37 PM by bscrive » Logged
Scottsscooter
« Reply #4 on: January 04, 2017, 06:00:43 PM »
I'll have all the parts shortly. Look forward to having a center stand... Thanks for idea's..
Scott
Jambriwal
« Reply #5 on: January 17, 2017, 01:02:20 PM »
Look on E Bay for gold Wing Trike take off parts.
Jim
