February 12, 2026, 08:58:25 PM
Fork Bushings Kits
Topic: Fork Bushings Kits (Read 1184 times)
Fork Bushings Kits
January 15, 2017, 05:02:38 AM »
http://www.hondadirectline.com/all-balls-fork-bushing-kit-detail.htm?productId=23177927&vmid=22225598
I see they have this fork bushing kits available from All Balls.
Anyone have any experiance with them?
Re: Fork Bushings Kits
January 15, 2017, 06:17:12 AM »
I rebuild forks for friends. The last set of parts were from all Balls. I found their seals were superior to OEM. The bushings were a perfect fit. No problems and I'd use them again.
January 15, 2017, 06:21:05 AM »
Quote from: sandy on January 15, 2017, 06:17:12 AM
Thanks for the reply. Sounds good.
Sparky51
Houston, TX
Houston, TX
January 15, 2017, 11:51:35 AM »
Now I am going to sound stupid. Fork Bushings versus fork seals? I heard a lot about changing fork seals, not so much about bushings. Care to enlighten this guy? Thanks
January 15, 2017, 12:07:47 PM »
Quote from: Sparky51 on January 15, 2017, 11:51:35 AM
Think of them sort of like bearings for the forks. They are just metal, but they eventually get worn.
January 15, 2017, 12:08:29 PM »
There are Brass bushings inside the forks that will wear with time and cause some slop in the legs going in and out of the sliders. Many replace those at the same time as the seals I know I do.
Reply #6 on:
January 15, 2017, 07:44:16 PM »
OEM's are teflon coated copper. The manual states that if 3/4 of the bushing is copper, meaning the teflon has worn, than replace.
Like Bighead, I just replace every time I open them up.
Sparky51
Houston, TX
Houston, TX
Reply #7 on:
January 16, 2017, 06:55:01 AM »
Thanks Guys! I love this board. So much of an education going on here.
Gabriel
Near Galveston
Reply #8 on:
January 18, 2017, 08:18:02 AM »
It looks like they don't contain the actual seals, unless I missed something?
Reply #9 on:
January 18, 2017, 04:55:13 PM »
Quote from: Gabriel on January 18, 2017, 08:18:02 AM
No, you're right, seals are not included.
