February 12, 2026, 10:19:12 PM
Shadow master cylinder
Topic: Shadow master cylinder (Read 886 times)
Mofla
San Antonio TX
January 28, 2017, 01:06:24 PM »
Anyone have any problems with these ? I replaced the original with these and was happy till clutch went out again. After popping the cap the fluid was black ?? Changed fluid , tried to speed bleed , but no luck getting any handle , clutch pressure back ? Could the o rings in the plunger have melted, letting fluid by pass ?? I rebuilt slave back when I started this process so it seemed to be good ,,,,bought the master Shadow pair of masters on e bay , wondering if the r sub quality ? Thanks for your thoughts ! Mofla
Blackduck
West Australia
Re: Shadow master cylinder
January 28, 2017, 04:53:03 PM »
With black fluid it sounds like the seals are disintegrating.
Where these genuine cylinders?
Would appear there is a compatibility issue with the fluid.
Would order parts from a reputable supplier and re-kit both cylinders.
Have you checked the fluid in the brake master? Could be in for a nasty surprise if that has the same problem.
Cheers Steve
Mofla
San Antonio TX
January 28, 2017, 07:51:58 PM »
My sentiment exactly !!
I did check the brake master, it appeared normal ,, maybe because clutch gets more motion ??? Thanks for your input , I'm hoping that is the case,, so looking for better quality ,,, hate doing sh__ twice !!
