April 28, 2026, 07:19:06 PM *
Author Topic: Electric help needed  (Read 2131 times)
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« on: February 05, 2017, 03:38:21 PM »
Hey Guys, my standard won't start.  She's been hooked to a trickle charger for about four months, with a green light the whole time, but when I hit the key nothing happens.  I have 13 volts on the battery off and 10 when I turn the key on and the only load is the lights.  It's a 3 year old Yuasa.  I checked the main fuse and the ignition fuse, both are good.    I get no clicks or whirs, I get nothing.  The trickle charge light goes immediately back to green when I turn the key off.
Battery?
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: February 05, 2017, 04:27:17 PM »
Battery?
That would be my guess.  Could also be starter switch or loose/corroded battery connections, but easiest thing to do is take the battery to an auto store and get it load tested.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
big poppa pump
San Antonio, TX
« Reply #2 on: February 05, 2017, 06:42:11 PM »
Battery voltage should be around 12.6V - 13.1V with the key turned on. 10V is way too low!
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
RainMaker
Arlington, TX
« Reply #3 on: February 07, 2017, 11:37:50 AM »
You could pull the battery out of your I/S and see what happens.  My guess is that the battery in the Standard won't start the I/S, either, but the I/S battery will start the Standard.
These AGM batteries are the real deal, by the way.  Have purchased 2 at Batteries Plus (for the 2 Valks) and they are strong!!!
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Houdini
Allen, TX
« Reply #4 on: February 08, 2017, 08:40:00 AM »
So I pulled my battery out of my IS yesterday and my standard roared to life.
My big disappointment is with the Yuasa battery, I generally get many trouble free years from them but this one barely lasted 3 years.
dancnman
Houston, Texas
« Reply #5 on: March 01, 2017, 09:23:13 AM »
Check out Chrome Batteries. I won't buy anything else. 30 bucks to my door last year or so. Google it.
Reality is that thing which does not change simply because I choose to ignore it.
