November 11, 2025, 10:01:23 PM *
Author Topic: Interstate rear brake pads?  (Read 4564 times)
« on: February 08, 2017, 09:45:12 AM »
Has anyone used the Interstate rear brake pads on the front of their Standard or Tourer?
I'm ordering up some parts and don't want to order front pads if the I/S rears work.
« Reply #1 on: February 08, 2017, 10:02:18 AM »
Just micked it up and it appears they won't work.
To bad, big diff in price, with the bigger I/S ones costing less  uglystupid2
« Reply #2 on: February 08, 2017, 11:09:55 AM »
The I/S rear pads are different than a standards ?
« Reply #3 on: February 08, 2017, 11:21:31 AM »
The whole rear caliper is different. The Interstate pistons
are smaller for some reason...
-Mike "and the Interstate caliper is painted black!"
« Reply #4 on: February 08, 2017, 11:59:50 AM »
Shocked I haven't checked the piston size on mine, but it is silver just like my standard. (Well dirty silver  Undecided)
« Reply #5 on: February 08, 2017, 12:01:26 PM »
calipers fully retracted they should fit. rear pads are 10mm thk, which is only 1.5mm thicker than front.
http://www.valkyrieforum.com/bbs/index.php/topic,7487.0.html
« Reply #6 on: February 08, 2017, 12:04:49 PM »
[/quote]
Dang. Do you have one of those green ones like Stanley Steamer?
Maybe they didn't paint them black every year?
I got a black Interstate rear caliper from eBay numerous years ago,
I thought they were all that way. There came a day that I really wanted
the pistons out of it, but they turned out to be smaller than my 97
Tourer's pistons...
-Mike "so I missed Britman's Memorial Day ride that year..."
« Reply #7 on: February 08, 2017, 12:54:59 PM »
Never took notice TIL now reading this but I looked ( as I am sitting in my garage ) mine are black and standard is silver Shocked
« Reply #8 on: February 08, 2017, 05:44:42 PM »
Rear pads for a Standard/Tourer
http://www.partzilla.com/parts/detail/honda/HP-06435-MZ0-006.html    $35.87
Rear pads for a Interstate
http://www.partzilla.com/parts/detail/honda/HP-06435-MBY-671.html    $21.75
I have a new set of each and the only difference I can find is the price.
Michvalk
Remus, Mi
« Reply #9 on: February 08, 2017, 06:13:48 PM »
I know my 99 caliper was silver. Maybe the newer one's were black cooldude
« Reply #10 on: February 08, 2017, 07:20:03 PM »
Mine is a '99
« Reply #11 on: February 08, 2017, 08:09:40 PM »
Interesting  Wink I haven't bought OEM in a while. I've been going with these off of Amazon. They seem good.
https://www.amazon.com/KMG-1997-1999-Valkyrie-Tourer-Organic/dp/B00BSAP35S/ref=sr_1_6?ie=UTF8&qid=1486614501&sr=8-6&keywords=valkyrie+brake+pads
« Reply #12 on: February 08, 2017, 08:35:19 PM »
I like the OEM's.  I feel the work the best.  I had a set of ECB on a bike I bought and they were noisey.
« Reply #13 on: February 09, 2017, 06:06:09 AM »
The rear pads I just took out of the OEM package mic out at 12.4mm.
The new front pads I just installed in the front calipers I'm rebuilding for a buddy, mic out to 8.3mm.
I took the front ones out of the caliper and installed the rears with the cylinders all the way in, just to see and there's no way there's enough space for the rotor to fit.
My guess why the I/S rears are less cost is, Honda has never had to reorder and is still working on original stock.
« Last Edit: February 09, 2017, 06:23:23 AM by Hook#3287 » Logged
falconbrother
« Reply #14 on: February 09, 2017, 01:19:13 PM »
I ordered organic front pads and installed them right before a multi day ride last summer.  Got into the Smokies, flying low down a mountain, laid on the front brakes hard for the next curve, they slowed me down but, smelled like they were on fire for a while.  I like them but, I sure don't expect them to last a long time.  I bought them cheap on Amazon.  Would I buy them again?  Heck yea.
1999 IS
bill-jr
VRCC # 35094
murfreesboro
« Reply #15 on: February 10, 2017, 02:36:35 PM »
Do u use the shiny pieces that come on the rear pads or take them off ???
  uglystupid2
99' Black tourer
« Reply #16 on: February 10, 2017, 03:53:15 PM »
  uglystupid2
Not sure if this is a real question or who "U" is?
« Reply #17 on: February 10, 2017, 06:26:07 PM »
  uglystupid2
I haven't had to do mine in several years, what with having two
bikes now... do you see "the shiny pieces" on here?
« Reply #18 on: February 10, 2017, 06:33:05 PM »
I think he's asking about the metal backing plate or he's just messing.
« Reply #19 on: February 10, 2017, 07:47:01 PM »
without the added metal spacer and backing plate which can be removed they are 10mm. I have a set that I just measured.
« Reply #20 on: February 11, 2017, 04:35:44 AM »
I've never considered modifying such an important part, have you done this?
It's just a spacer and not structural to the pad?
« Reply #21 on: February 11, 2017, 06:55:51 AM »
just a spacer that basically clips on. I've done cars/trucks whereas the metal spacer is loose in the box and has to be installed on the pad before install.
just pry the taps away and then pop it off.
I installed Vesrah front pads which are 9.5mm, they fit with room to spare.
http://catalog.vesrah.co.jp/index_street_f.html
« Reply #22 on: February 12, 2017, 10:46:44 AM »
Had the time to check out the rear I/S pads I got for $20.00 from Procaliber.com.   Took off the spacers, put em in the front caliper and they fit.  Thanks for the info CA cooldude
« Reply #23 on: February 12, 2017, 10:51:55 AM »
  uglystupid2
Mike, yeah, they're there.  You can see the metal tabs.  No reason to remove them in the rear caliper.  I wonder what their purpose is?  Maybe so as they wear you don't use more fluid than is in the master?
« Reply #24 on: February 12, 2017, 10:53:23 AM »
  uglystupid2
Sorry I misunderstood your question, it makes perfect sense now uglystupid2
« Reply #25 on: February 12, 2017, 10:53:48 AM »
Hey Bill, what spacers are you guys referring to ?
« Reply #26 on: February 12, 2017, 10:58:56 AM »
These.  If you look at Mike's picture, you can see them on the pads.
« Reply #27 on: February 12, 2017, 11:21:19 AM »
Regarding the latest pics on Hook#3287 post
What you are seeing: the white looking pads and the stainless looking plates are actually heat insulators designed to keep the heat, generated by strong braking, from migrating to the pistons and caliper and possibly causing the brake fluid to react in a dangerous way, such as boiling.
Boiling brake fluid can cause the brake system to activate thereby locking the brakes.
Since the rear brake has a single caliper and additionally since it is the rear brake that can see more brake pressure exerted, it can be subjected to considerably stronger braking forces resulting in much higher operating temperatures.
« Reply #28 on: February 12, 2017, 11:32:34 AM »
and also less airflow than what the fronts see will increase temps.
« Reply #29 on: February 12, 2017, 12:49:13 PM »
Awh, heat insulators, makes sense.
« Last Edit: February 12, 2017, 12:51:32 PM by Hook#3287 » Logged
bill-jr
VRCC # 35094
murfreesboro
« Reply #30 on: February 13, 2017, 12:21:30 PM »
Ive always taken them off and chunked'em ....?!?
Maybe i should start leaving them on??
99' Black tourer
« Reply #31 on: February 13, 2017, 12:46:15 PM »
Ive been using aftermarket ones for so long that I forgot about OEM having them. No issues for me, but I don't use my back brake that much. Probably 45-50k out of the back and 20-25k out of the fronts.
Unlaoised
Ireland
« Reply #32 on: June 21, 2022, 11:55:37 AM »
So I ended up buying 3 sets of OEM Interstate pads (06435-MBY-671) by mistake.  tickedoff
Based on what I'm reading here, if I take off the back pad they should fit the front calipers.
What about the rear, will they fit if I remove the pad?
« Reply #33 on: June 22, 2022, 04:03:23 AM »
I'm running interstate rears in all calipers.
No reason to remove heat shield in rear caliper.
« Reply #34 on: June 22, 2022, 06:49:47 AM »
After reading what’s here. Why would you want to remove the heat shields if you are using them in the rear, where they are designed to fit as they are?
Unlaoised
Ireland
« Reply #35 on: June 23, 2022, 01:36:47 AM »
From what I gather, the interstate pads will fit as is on the rear calipers, but the heat shield/metal backing plate will need to be removed for them to fit in the front calipers.
Either way, I will confirm later as I have 3 sets of Interstate pads that I'm planning to use on my standard today...
Unlaoised
Ireland
« Reply #36 on: June 23, 2022, 04:01:01 AM »
These Interstate pads fit the rear of a '98 standard as they are (with metal pad/spacer etc).
They also fit the front calipers , however I needed to remove the metal pad and spacer (10 second job)!
Case closed!
« Last Edit: June 23, 2022, 04:03:34 AM by Unlaoised » Logged
Avanti
Stoughton, Wisconsin
« Reply #37 on: June 23, 2022, 06:01:02 PM »
If have an Interstate and have been using rear pads both front and rear for a number of years. I get better service life on front and less piston exposed to the elements.
