February 12, 2026, 08:59:31 PM
Other Carb Adj. Screw...
Topic: Other Carb Adj. Screw... (Read 1192 times)
mrgeoff
My 99 CT..."Liahona"
Augusta, GA.
February 08, 2017, 08:34:48 PM »
Hey...I know about the Pilot Adj. Screws, but what are the Phillip type screws that are on the carbs that you can turn to increase/decrease the idle?...They are facing out so you can just put a screwdriver on them...??? Is there a base standard adjustment in term of number of turns, to set them up while the bike is running...??? I keep my Idle Adj. Knob set for 1000 rpm...Adj. these screws for the 5 carbs makes the idle increase/decrease...!!! How would I go about Adj. these screws so as to get the best idle from each of my carbs...??? Hope I have explained this properly...!!! Thanks for all you do...!!! I have a 99 CT...!!!
mrgeoff/SANDMAN
Re: Other Carb Adj. Screw...
February 08, 2017, 08:38:09 PM »
If your talking about the blue or green painted phillips screws, those are the carb sync adjustors and you will need a carb sync, if you messed with them.
mrgeoff
Augusta, GA.
February 08, 2017, 08:54:19 PM »
These aren't green or blue...maybe they are just old...!!!
mrgeoff/SANDMAN
February 08, 2017, 09:20:34 PM »
Is this what you're talking about?
Harryc
Sebastian, Fl
February 09, 2017, 12:41:38 AM »
Beside the carb sync adjusters which Hook#3287 pointed out, the only other screws facing out are the bowl drain screws. Don't turn those out unless you want a puddle on the floor.
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
bulldog620
Let's take our country back!! Semper Fi
Ellijay, GA
February 09, 2017, 04:36:50 AM »
if you are talking about the screws in the picture that Hook posted, and you turned them and she ain't running right, then you need the carbs sync. I'm up in Ellijay, I'd be happy to do it for you, should take less than an hour.
Last Edit: February 09, 2017, 04:39:03 AM by bulldog620
Ramie
2001 I/S St. Michael MN
Reply #6 on:
February 09, 2017, 05:19:45 AM »
The idle adjustment is a knurled nob on the right side towards the front.
“I am not a courageous person by nature. I have simply discovered that, at certain key moments in this life, you must find courage in yourself, in order to move forward and live. It is like a muscle and it must be exercised, first a little, and then more and more. A deep breath and a leap.”
mrgeoff
Augusta, GA.
Reply #7 on:
February 11, 2017, 08:45:43 PM »
Yep...The pic shows the screws I'm talking about...!!!
Thanks...!!!
mrgeoff/SANDMAN
Reply #8 on:
February 12, 2017, 06:51:56 AM »
Quote from: SillyOleBear on February 11, 2017, 08:45:43 PM
Thanks...!!!
While turning them will change your bikes idling, that is not what they're for.
You should have your carbs synchronized.
