February 12, 2026, 08:58:34 PM
Desmog without removing Cobra pipes?
Topic: Desmog without removing Cobra pipes? (Read 810 times)
Wayn-O
Orem, UT
February 10, 2017, 09:55:18 AM »
I have the shiny desmog kit and want to install it this weekend. I just wanted to confirm that I won't have to remove my cobra exhaust in order to do so. Anyone done this?
2000 GL1500C Valkyrie
2003 VT1100C Shadow Spirit
1998 VT1100C Shadow Spirit
1983 VF750C V45 Magna
Harryc
Sebastian, Fl
Re: Desmog without removing Cobra pipes?
February 10, 2017, 10:43:11 AM »
I've done it without removing the stock exhaust. I'd guess Cobra is similar. You do need some patience though because it's not easy to get to the fasteners on the bottom of the engine with the exhaust in the way. The way I look at it is try it ... you have nothing to lose. If you can't get to what you need to then drop the exhaust. All it will cost you is time and some exhaust gaskets.
Last Edit: February 10, 2017, 10:47:55 AM by Harryc
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
February 10, 2017, 11:07:16 AM »
I've desmogged most of my bikes by just crimping and folding over the pair tubes. Fast & easy and cheap & looks OK to me. No need to even look under the heads. Form follows function.
Wayn-O
Orem, UT
February 14, 2017, 11:21:08 AM »
Update for future readers:
It is possible. I did it. Probably not as easy, but doable.
