Valk4us
« on: February 18, 2017, 05:37:37 AM » |
I tried doing search, but there's to much to weed through.
« Reply #1 on: February 18, 2017, 05:47:05 AM » |
Yes, you can work on the clutch with the motor in the frame.
-Mike "I haven't worked on my clutch..."
Valk4us
« Reply #2 on: February 18, 2017, 06:02:49 AM » |
Is it a pain in the ass to do it that way?
« Reply #3 on: February 18, 2017, 06:42:53 AM » |
not hard at all, plenty of room. air gun makes removal of clutch basket easier. only the GL1200 requires engine removal, some say only partial. GL1000, GL1100 and GL1500 and Valkyries can be done with engine in place.
plenty of how to's on this forum.
Valk4us
« Reply #4 on: February 18, 2017, 07:06:30 AM » |
Thanks all!
« Reply #5 on: February 18, 2017, 07:57:22 AM » |
Thanks all!
edit your profile as to your location, might be member near u who has already done the deed.
Valk4us
« Reply #6 on: February 18, 2017, 10:47:59 AM » |
Will do, I haven't been on the forum in a good while but it's good to be back
matt
« Reply #7 on: February 18, 2017, 11:08:00 AM » |
It is do able, did not remember if you said on a lift? I did it on the ground supported bike with four jack stands as you need to be able to get were bike lift goes. Definitely tight you probably wont need a new cover gasket but I say get one. Two reasons 1 : you dont want an oil leak when done 2: it shows you what bolts to remove.
« Reply #8 on: February 18, 2017, 02:02:07 PM » |
There was a nice multi picture how-to posted here long ago. The fingers in the pictures had nail polish.  (Tracy)
Valk4us
« Reply #9 on: February 18, 2017, 02:48:36 PM » |
There was a nice multi picture how-to posted here long ago. The fingers in the pictures had nail polish.  (Tracy) You wouldn't happen to know where that post might be. I did a search and came up empty?
« Reply #10 on: February 18, 2017, 03:21:24 PM » |
Valk4us
« Reply #11 on: February 18, 2017, 05:44:48 PM » |
Awesome thanks
matt
« Reply #12 on: February 18, 2017, 06:27:49 PM » |
Why do you think you need a clutch? If there is a thread on it sorry did not see it. I had purchased a basket on ebay for cheap and made a tool to hold to disassemble clutch pack and used worn basket to line up disks
Valk4us
« Reply #13 on: February 19, 2017, 05:58:01 AM » |
It's definitely slipping, I'm pretty hard on it. I've got all the home made tools because I've had it apart before, because I had the dredded hydro lock (twice). It took the motor out and set it on a bench to fix it. It broke the rear cover so I ended up buying another motor to get a replacement.
« Last Edit: February 19, 2017, 06:16:40 AM by Valk4us »
Avanti
« Reply #14 on: February 19, 2017, 06:34:51 AM » |
I remove the seat, the side covers, the gas tank and center cover; in this order. I also tie off the handlebars. Then I use an overhead hoist, lifting the entire motorcycle from the balancing point using straps on the frame. I raise as high as makes it comfortable to work on and set the wheels down on two separate resting points to steady it, but still hanging from hoist. This allows for a lot of working room.
« Reply #15 on: February 19, 2017, 06:36:52 AM » |
It slipping could be as simple as the clutch lever. Put on some Crome ones once and the plunger was sticking and the clutch would slip at WOT. Took it apart and a bit of cleaning and lube and all was good and that was 50+k miles ago.
Valk4us
« Reply #16 on: February 19, 2017, 06:48:25 AM » |
Yes I actually remember I ran into the same problem, but you know it's been a while, I'll give it another look. Thanks
« Last Edit: February 19, 2017, 07:02:20 AM by Valk4us »
« Reply #17 on: February 19, 2017, 06:50:42 AM » |
 One thing I've learned from this board is too check the easy cheap things first.
« Reply #18 on: February 19, 2017, 09:13:19 AM » |
From: Hook#3287 One thing I've learned from this board is too check the easy cheap things first. Even better is to occasionally perform a little maintenance of the bike like lubricate things like the levers, foot brake, carburetor linkage, throttle cables & grip, and more. This is probably the most neglected area by Valkyrie owners. ***
« Reply #19 on: February 19, 2017, 09:36:32 AM » |
From: Hook#3287 One thing I've learned from this board is too check the easy cheap things first. Even better is to occasionally perform a little maintenance of the bike like lubricate things like the levers, foot brake, carburetor linkage, throttle cables & grip, and more. This is probably the most neglected area by Valkyrie owners. *** Yup! Guilty. Just get on it and ride. Annual maintenance only. Trying to put together a to-do list of things I should do to the bike at my spring maintenance day.
« Reply #20 on: February 19, 2017, 09:42:43 AM » |
From: Hook#3287 One thing I've learned from this board is too check the easy cheap things first. Even better is to occasionally perform a little maintenance of the bike like lubricate things like the levers, foot brake, carburetor linkage, throttle cables & grip, and more. This is probably the most neglected area by Valkyrie owners. *** Yup! Guilty. Just get on it and ride. Annual maintenance only. Trying to put together a to-do list of things I should do to the bike at my spring maintenance day. one of the things I'm doing right now is preserving the swing arm. A lot of surface rust some places under the paint near the welds. blew out the slots and drain hole, then sprayed Eastwood internal frame coating. also very bottom of the fender above the swing arm had some mild rust also.
