March 15, 2026, 08:26:57 AM *
Author Topic: Revelation: Tire pressures.  (Read 2981 times)
AdrianR
Far North Chicago Burbs'
« on: February 18, 2017, 10:02:04 PM »
Setting the tire pressures to what the manual recommends is the best way to go.
36psi front, 41 rear.
Suspension dampening turned down all the way.
World of difference in ride comfort, stability..(especially high speed)..and neutral steering characteristics.
Also, man, the NGK plugs really made a nice a difference over the stock Densos...  Engine even sounds different... This thing just keeps getting smoother...and sounds great....very unique.
Shrubbo
Australia
« Reply #1 on: February 18, 2017, 11:25:11 PM »
Gets even smoother if you let the rear down to like 10 psi. Man it just sucks up those bumps but it is probably not the recommended thing for some reason  uglystupid2
2014 Valkyrie, crap stuck on it everywhere!
« Reply #2 on: February 19, 2017, 03:20:28 PM »
I think you will find on the 36 tire pressure a bit low, the bike will handle ok  not the best but the tire will wear poorly. I have already had the tires at that pressure and found it led to choppy wear. 42 is to high and rough I would say about 39 or 40 would be a compromise. I have mine up at 42 right now and am going to drop it back to 39 or 40 for comfort. As for the rear I say 41 is just about right.
AdrianR
« Reply #3 on: February 19, 2017, 07:21:38 PM »
If there is one thing about this bike I do not like is how critical the front tire pressure is.  Man, when the front tire pressure starts to get too close to 40 or more, man does it over steer...
allhans4
Land O Lakes, FL
« Reply #4 on: February 20, 2017, 11:43:21 AM »
I took the suspension down to zero, but found it a bit squirrelly.  Was riding at about 10 clicks of the knob.
Now I am 5 clicks up from zero -- that's the sweet spot for me.
 angel
2014 Honda Valkyrie
Blue Metallic
