February 12, 2026, 10:43:08 PM *
Author Topic: need tips on how to wire in 2 led fog lights.  (Read 1032 times)
archerdude
« on: February 23, 2017, 02:10:28 PM »
I have 2 small LED mini spot lights that I will probably mount to my crash bar or front fender but Im not sure on where to connect the wires to. I have a cymers manual for Valkyrie and I can see the wiring diagrams. Any tips or suggestions? Thanks guys! Jeff
« Reply #1 on: February 23, 2017, 04:18:55 PM »
Are you wanting to switch them separately or have them come on with the headlight ?
Ramie
2001 I/S St. Michael MN
« Reply #2 on: February 24, 2017, 06:06:41 AM »
http://www.rattlebars.com/mtz/foglites.html
archerdude
« Reply #3 on: February 24, 2017, 01:27:14 PM »
I want them to come on with the headlight..
« Reply #4 on: February 24, 2017, 04:30:58 PM »
Electrical work is not my forte, but this is how I would do it. Tap into the headlight wire, and use that as a trigger for a relay. Have the main wiring come from your battery or preferably if you have it a fuse panel such as the PC-8. Hopefully if my way is in error somebody will correct it.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #5 on: February 25, 2017, 01:30:19 AM »
http://www.valkyrieforum.com/bbs/index.php/topic,56705.msg546076.html#msg546076
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
