February 12, 2026, 10:42:48 PM *
Author Topic: CB Removal  (Read 1149 times)
Lyle Laun
Calgary, Ab
« on: February 24, 2017, 03:48:39 PM »
I'm planning on removing the CB on my Interstate. I can't find any instructions in my manuals or with the search button. I plan to start under the trunk and just keep following stuff until it's out. Hoping it's straightforward.
Anybody have any tips or advice ?
Lyle
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
« Reply #1 on: February 24, 2017, 03:59:52 PM »
Unless you are going to sell cut the lines and pull 2funny that is what I did with my intercom stuff.
« Last Edit: February 24, 2017, 04:42:25 PM by Bighead » Logged
Dusty
Mill Bay B.C.
« Reply #2 on: February 24, 2017, 04:02:52 PM »
 Un plug tail light wire and rear speaker wire (if equipped) under right side cover. Feed wire out so trunk can be removed . Unbolt the trunk from the rails (bolts in trunk bottom under plastic plugs) and remove. Remove four bolts that hold the CB carrier . Remove antenna and power plug under seat. Done
Dusty
« Reply #3 on: February 24, 2017, 04:40:10 PM »
You can find the manual on how to install here.
http://valkyrienorway.com/download.html
Just follow it in reverse.
NO! Don't just cut and pull.
Lyle Laun
Calgary, Ab
« Reply #4 on: February 24, 2017, 07:14:07 PM »
Gordon
I couldn't find anything in the Honda or the Clymer manual.
Lyle
Get out & Ride !!
Steel cowboy
Spring Hill, Fl.
« Reply #5 on: February 24, 2017, 07:18:27 PM »
Lyle, just asking, why are you removing the CB
2001 black interstate
2003 Jupiter Orange wing
« Reply #6 on: February 24, 2017, 07:40:00 PM »
Why not? If he is removing it he won't be putting it back so what's the harm?
Lyle Laun
Calgary, Ab
« Reply #7 on: February 24, 2017, 07:46:53 PM »
I'm selling the CB as I don't use it. I'm good with the backend removal but am trying to figure out what wires go forward to the handlebar controls. I'm assuming that I will need to pull the tank and disconnect wires closer to the handlebar control.
Lyle
Get out & Ride !!
ridingron
Orlando
« Reply #8 on: February 24, 2017, 09:03:19 PM »
As these bikes get older, the fewer parts are available. Ask someone to help if you don't know how to do something.
 Why destroy something that we have fewer and fewer of? Just my two cents.
SCain
Rio Rancho, NM
« Reply #9 on: February 25, 2017, 05:53:51 AM »
Lyle,
Nothing runs up to the handle bar control from the CB, the CB plugs into the radio under the seat and there is also a plug under the right side cover.
Steve
Lyle Laun
Calgary, Ab
« Reply #10 on: February 25, 2017, 07:24:10 AM »
Perfect, thanks guys
Much appreciated
Get out & Ride !!
« Reply #11 on: February 25, 2017, 10:53:46 AM »
The link I posted is for other manuals, which includes the CB install for the IS and the std/tourer bikes.
You won't find it in the repair/service manual.
3rd down on the link.
Like mention, it is basically 2 into the radio, and the ant.
But there are extras and the hidden noise suppressor to. Where was the CB mounted? Under the trunk, then there is the brackets too.
The head set plugs, those are OEM and stay with the bike for the intercom which doesn't require the CB.
« Last Edit: February 25, 2017, 10:55:47 AM by gordonv » Logged
Lyle Laun
Calgary, Ab
« Reply #12 on: February 25, 2017, 11:38:25 AM »
Thanks Gordon, never even looked, thought it was just the manual on Dag's sight. Anyhow, it's already out.
Cheers
Lyle
Get out & Ride !!
Stick
Sherbrooke Nova Scotia
« Reply #13 on: February 25, 2017, 04:03:54 PM »
Are you selling CB set up? What would you want for complete unit
2001 Valkyrie Interstate Burgundy/Black*Sold*
2000 Valkyrie Interstate-Black*Sold*
2000 Valkyrie Supervalk-Blue/Silver*Sold*
franco6
Houston, TX
« Reply #14 on: February 27, 2017, 09:16:53 AM »
Same question
Enjoy the ride!
Lyle Laun
Calgary, Ab
« Reply #15 on: February 27, 2017, 04:30:05 PM »
Sorry guys - It was sold before I pulled it off.
Lyle
Get out & Ride !!
PAVALKER
Pittsburgh, Pa
« Reply #16 on: February 28, 2017, 08:45:12 AM »
 Shocked  uglystupid2 coolsmiley
John
