BudMan
"Two's in."
Tecumseh OK
« on: October 11, 2009, 04:43:30 PM » |
I am looking for a “foot” to go on my kick stand to give a bigger ground contact and decrease the lean angle “just a smidget”. I recently changed rear tires and now the lean angle is just a little more than it was and I want it back the way it was.  (I don’t want to change tires again just for that.) It’s not bad, I just liked it better before. I’m not real big on change.
Buddy Tecumseh OK MOOT# 263 VRCC # 30158 1948 EL Harley 2013 F6B Delux "I rarely end up where I was intending to go, but often I end up somewhere that I needed to be," Dirk Gently; Holistic Detective
Old Geezer Richard
« Reply #1 on: October 11, 2009, 06:20:23 PM » |
Hey Budman , I had the same problem with my Valk and I was looking for that foot that slides onto your kickstand foot from Rivco and it has been discontinued , why I don't know ..... but I had read on the forum that one of the guys used that Rivco foot for a VTX on his valk and it worked .... he said he had to do some grinding on his Valk kick stand foot to make it fit , and it works he said ..... but you know what since I went darkside I don't have that much of a lean anymore ... Thanks Old Geezer Richard
If you don't care where you're going, then you ain't lost , Murphy's Law because wherever you are going to , it ain't going nowhere .... San Antonio,Tx.
John U.
« Reply #2 on: October 11, 2009, 06:22:19 PM » |
PharmBoy
« Reply #3 on: October 12, 2009, 04:57:14 AM » |
Budman, I have an extra side stand that we can grind on and the grinder if you want to try it. Bring the wife and come on down when you get the part in...JTL
A politician is a fellow who will lay down your life for his country. ~Texas Guinan 4th Infantry Tet Vet 99 Interstate 97 Bumble Bee 97 Red & White
Spirited-6
« Reply #4 on: October 12, 2009, 06:24:14 AM » |
Hey Budman , I had the same problem with my Valk and I was looking for that foot that slides onto your kickstand foot from Rivco and it has been discontinued , why I don't know ..... but I had read on the forum that one of the guys used that Rivco foot for a VTX on his valk and it worked .... he said he had to do some grinding on his Valk kick stand foot to make it fit , and it works he said ..... but you know what since I went darkside I don't have that much of a lean anymore ... Thanks Old Geezer Richard  I did use the Rivco for the VTX and works great. Amazing how much a little extra lift makes getting the Valk. off side stand a lot easier. I used a Demel to grind a little off to make fit. You do need to paint silver to stop rust.
Spirited-6
BudMan
"Two's in."
Tecumseh OK
« Reply #5 on: October 12, 2009, 09:17:11 AM » |
Outstanding! I knew you guys would have the solution. My only concern was making a change to the stand and then wanting to go back to not using it. Once again Pharmboy comes through with the solution to that problemeven before I said it! Thank you all so much!
HOZ
If it an't broke, don't fix it
Arlington, Wa.
« Reply #6 on: October 12, 2009, 10:18:50 AM » |
Ordered mine today. Was looking for one and ended up drilling 2 holes and bolting on (2) 1/4" pieces of alumunum bar stock 1 1/2" wide to the bottom side, works but not to pretty. Will like the chrome shiny pad better.
VRCC #1555 98' Tourer (Black) 157,000mi 99' I/S (Green & Silver) 45,700mi
BudMan
"Two's in."
Tecumseh OK
« Reply #7 on: October 12, 2009, 11:58:09 AM » |
Mine is supposed to be “in the mail” now too!  I hope to get it installed before leaving for the Great Smokey Mts. on the 23rd. We wanted to do the Fall Colors Ride but could not get our scheduled to cooperate. We’ll just be a week late.  I’ll give you a holler as soon as the part comes in, Pharmboy. Looks like the weather will make for a good ride this weekend.
PharmBoy
« Reply #8 on: October 13, 2009, 09:25:09 AM » |
Sounds good, Budman! This shouldn't take very long for the fit and install...JTL
BudMan
"Two's in."
Tecumseh OK
« Reply #9 on: October 13, 2009, 06:28:53 PM » |
OK, but under no circumstances are we going to town looking for O rings or tire mounting!
« Reply #11 on: October 21, 2009, 07:03:40 AM » |
Huummm, I keep a chunk of 1X4 in the saddlebag and throw it down if I have to park on new blacktop.. If somebody steals it, I don't care, but then, why would anyone want to steal it..
BudMan
"Two's in."
Tecumseh OK
« Reply #12 on: October 21, 2009, 04:01:04 PM » |
Yeah, I've done that a lot growing up in Mississippi where our tar melts regularly in the summer. I just want something I can't drive off and forget.
« Reply #13 on: October 21, 2009, 05:41:00 PM » |
I have a big switch box cover, about 4' of cord, plate on one end, loop on the other. Loop goes on my clutch master cylinder when I drop the plate on the ground. I also have the Rivco foot, haven't rode off without either one in several years...... Between the plate and the Rivco foot, MGM has not even come close to faling over. Plate has sunk in a few times where it was almost impossible to pull up.
