February 12, 2026, 10:42:52 PM *
Author Topic: Progressive 412 Bushing Replacement  (Read 1621 times)
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« on: March 05, 2017, 07:45:37 PM »
Any ideas or tricks that work to replace rubber/poly bushings at home?  Searched you tube but bushings on those are bigger from side to side or they don't have the lip that my replacement bushings have.
All ideas and help are appreciated.
Inzane is less than 4 months away
Michael
1997 GL1500C - Black
1997 GL1500C - Purple
1997 GL1500C - Bumble Bee
1998 GL1500C - Blue and Cream
big poppa pump
San Antonio, TX
« Reply #1 on: March 05, 2017, 08:15:39 PM »
Cut the old ones out. Use some WD40 silicone spray on the new ones and use a vise clamp to press them in.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Beardo
Regina, Saskatchewan Canada
« Reply #2 on: March 06, 2017, 04:40:57 AM »
2 sockets and a vice. One socket to fit around the bushing on the shock mount on one side, a smaller socket on the other side, small enough to fit through the shock mount and push the bushing out and into the big socket on the other side. If you don't have a vice, a bigger c-clamp would work, but might require a second set of hands.
To get the new ones in, just use the vice.
« Last Edit: March 06, 2017, 04:42:45 AM by Beardo » Logged
rhinor61
Northern California
« Reply #3 on: March 06, 2017, 08:22:57 AM »
FYI, WD-40 is the trademark name of a penetrating oil and water-displacing spray.
Is not a very good lubricant. Water Displacement(WD) Oil will destroy your rubber bushings.
Never spray it on your gun collection either.
Use silicone spray or dawn dish soap.
I find the only reason to have WD-40 in my garage is for killing wasp or ants when used with a bic lighter.
my 2 cents
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
Harryc
Sebastian, Fl
« Reply #4 on: March 06, 2017, 01:53:40 PM »
I recently found a good set of Interstate rear shocks for my Tourer and replaced the bushings with neoprene ones from Redeye before installing them. I saw some youtube videos of guys building special jigs to remove and install them....on and on. I pushed out the old bushings with a pair of pliers, lubed the new ones with silicon and pushed them in with my fingers. Maybe I don't know my own strength but man it was not hard. Sometimes there's too much drama over small stuff. Smiley It's just a bushing, you'll figure it out.
« Last Edit: March 06, 2017, 01:58:33 PM by Harryc » Logged
97BLKVALK
VRCC#26021
Detroit Lakes, MN
« Reply #5 on: March 06, 2017, 04:15:09 PM »
Harry, you're correct.
I think about it too much and with being stuck inside and no heat in garage tendencies  lean towards OCD  thinking.
Lol   haha
Michael
