February 13, 2026, 05:07:21 AM
Valve stems
Topic: Valve stems (Read 922 times)
Davemn
Minnetrista, Minnesota
Valve stems
March 18, 2017, 08:26:14 AM »
Changing rear tire next week. Recommend a new valve stem? Does an independent shop have such an item? Dealer?
Harryc
Sebastian, Fl
Re: Valve stems
March 18, 2017, 08:50:22 AM »
Here you go ...
https://www.jakewilson.com/p/1753/-/162103/Myers-90%C2%B0-Tubeless-Chrome-Valve-Stem?term=1196640001
http://s724.photobucket.com/user/Harryc56/slideshow/Valkyrie
jim@98valkyrie.com
Wayne, PA
Re: Valve stems
March 18, 2017, 09:50:13 AM »
Amazon and several others have them as well. They are Myers 90 deg. Look for the ones that have the nut on the outside of the rim.
Unless you get a large enough order together, seems shipping is around $7.
https://www.amazon.com/gp/product/B003O6SJEQ/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Re: Valve stems
March 18, 2017, 03:19:55 PM »
A new rubber stem at EVERY tire change is OK and the shop should have them. If they don't do it, then I would never bring anything back to them to work on. It's your life.
As for the metal one recommended above, that is the way to go and should last, what ?, forever?
You just missed the sale Jake Wilson had, no minimum for free shipping. I bought like 4-6 valve stems just so I would have on hand. Even though I bought the 90' ones, I wonder why not stubby short ones? But I want the nut on the outside, so it can be tightened more if found leaking.
Last Edit: March 18, 2017, 03:24:17 PM by gordonv
da prez
Wilmot Wi
Re: Valve stems
March 18, 2017, 09:10:41 PM »
PM me with an address and I will send you a couple.
da prez
