November 27, 2025, 05:13:37 PM *
Author Topic: carbs  (Read 835 times)
« on: April 04, 2017, 07:19:18 AM »
Has anyone changed a float and float needle with the carbs still on the bike? I know i have heard of some replacing jets with them still on. I would think you would have to pull the float to get to the jets. It's been a couple years since i have had mine off and opened up.
« Reply #1 on: April 04, 2017, 08:17:16 AM »
Git in touch with AtticRat. RIDE SAFE.
SCain
Rio Rancho, NM
« Reply #2 on: April 04, 2017, 08:22:28 AM »
The jets are easily removed without taking out the floats, if you are just changing jets I wouldn't remove the floats.
But if you are that far into the carb already, might be a good idea to remove the float and inspect the float needle, I guess it would depend on why you opened them up in the first place.
Steve
« Reply #3 on: April 04, 2017, 08:38:56 AM »
it hydrolocked on the #2 cylinder so i'm replacing the float and needle on that carb. i just didn't want to pull the carbs if it can be done without removing them.
« Reply #4 on: April 08, 2017, 06:10:17 AM »
Turns out you can replace float and float needle with them in place.  cooldude did it last night over a couple hours and a beer or 3. Now I have back firing on that side and smells really rich. Going to turn my mixture screws in to 1 3/4 and resync today. My pipes are really open so I dont think turning the screws in by 1/2 a turn will hurt
