February 13, 2026, 02:51:29 AM *
Author Topic: Thumb Screw for Trip Meter  (Read 981 times)
Carl
Friendswood, Tx
« on: April 13, 2017, 02:59:36 PM »
The head of the 2mm screw that holds the thumbscrew on the trip meter broke off.  I am trying to figure out a way to get that screw out. It broke off flush with the mount.  I can't find an EZOut that small.  I thought I might try a left hand drill bit, if I can find one that small.
I was wondering if anybody here has faced a similar problem, and what was the solution.
« Reply #1 on: April 13, 2017, 03:54:26 PM »
Did you remove the case from the speedometer?
Gideon
Indianapolis, IN.
« Reply #2 on: April 13, 2017, 07:00:30 PM »
Do as Chris asked.
The same thing happened to me.
Thanks to this forum, I removed the case from the speedometer and found it to be an easy fix.  cooldude
Gabriel
Near Galveston
« Reply #3 on: April 15, 2017, 06:03:25 AM »
Glad to know that, I'll probably break mine next week?
Roidfingers
Tuscaloosa, Alabama
« Reply #4 on: April 15, 2017, 05:10:58 PM »
Take your small drill bit. Break it at the thread then invert it. put in drill then reverse.
