February 13, 2026, 05:07:02 AM *
Author Topic: Purchase of Audiovox CCS-100 from Murphs Kits?  (Read 4138 times)
RckyMtnRider
Parker, CO
« on: April 28, 2017, 09:29:04 PM »
I've been doing a lot of reading on the VRCC forum about installing the Audiovox cruise control on a Valkyrie Interstate. The only place I found to purchase the CCS-100 is from https://www.murphskits.com/product_info.php?products_id=422. I'm just wondering if anyone has purchased one of these units recently? Is this a recommended site? Is there another seller that I should research?
RckyMtnRider
« Last Edit: April 28, 2017, 10:00:48 PM by RckyMtnRider » Logged
Novavalker
99 Interstate/2017 Goldwing
« Reply #1 on: April 29, 2017, 02:36:45 AM »
I bought mine from them and installed it on my Interstate a few years ago. No problems with it at all and I use it all the time.
Firefighter
Harlingen, Texas
« Reply #2 on: April 29, 2017, 04:18:57 AM »
Bought mine their also and installed myself, will be five years in May. Under 200.00 . Can follow almost step by step instructions with pictures on this site. I use my cruise control all the time, and along with the center stand and airhawk seat cushion is the best investments I ever made!
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
RckyMtnRider
Parker, CO
« Reply #3 on: April 29, 2017, 06:09:53 AM »
Thanks for the feedback. I'll be purchasing one.
RckyMtnRider
Parker, CO
« Reply #4 on: April 29, 2017, 06:24:16 AM »
Another question. Did you build the vacuum canister as described in the Shoptalk article, or did you buy one?
RckyMtnRider
« Reply #5 on: April 29, 2017, 10:34:43 AM »
I bought the original, NOS, and hope to install it before the Valhalla and IZ trip this year. But I'll be also replacing the intake o-rings, and desmogging, so I'll have more room. Figured I'm in there, might as well do it all.
I've read all I could find over the years. I was just going to hook it up to one vacuum port, and see how it fairs. But was also toying with the idea of a small "bottle" with 2 in and 1 out vacuum lines, and run that up to the activator, again, while there. Maybe something along the lines of 2" PBC pipe, maybe 4" long and end caps. Just something to balance out the vacuum pull, connected to opposite cylinders.
« Reply #6 on: April 29, 2017, 11:51:45 AM »
RckyMtnRider
Mine doesn't have the vacuum canister and it works just fine. It has a vacuum line from each #3 and #4 with check valves in line then T'd together.
mrtlc
Elroy WI
« Reply #7 on: April 29, 2017, 03:03:51 PM »
Don't they make an electric one? I would think losing some vacuum from a couple of carbs would affect those carbs. It would be interesting to put a Digisync on one and see how it affects the vacuum. I'd also like to put a cruise on.
99 Interstate 1500
89 Goldwing sidecar 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
Firefighter
Harlingen, Texas
« Reply #8 on: April 29, 2017, 03:23:22 PM »
Think I used five vacuum ports, tee them together with two lines going to the canister. I usually over due things. I made a pvc canister but liked the factory one better and used that. I mounted everything vacuum motor, canister under faring. I purchased the one way vacuum valves (can't remember what they are called) from a local auto air company. Made a little bracket out of aluminum to mount the switch, fits next to the choke lever. Works slick! Take your time and follow the instructions, route hoses and wiring, fuse, with care so as no chafing, or burning, take your time. If any questions there will be plenty of answers.
1978 Honda 750
« Reply #9 on: April 29, 2017, 06:05:16 PM »
You are not really losing vacuum. It's sealed. I have Digisynched mine, all is good.  cooldude
mrtlc
Elroy WI
« Reply #10 on: April 29, 2017, 07:30:49 PM »
Good to know cooldude
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
N0tac0p
« Reply #11 on: May 01, 2017, 06:56:21 AM »
anyone chime in on the electric one?
mrtlc
Elroy WI
« Reply #12 on: May 01, 2017, 04:09:37 PM »
https://www.murphskits.com/product_info.php?cPath=25&products_id=369
Rostra Electronic Cruise Control
I know nothing about  them, but look very interesting. Anybody using one?
99 Interstate 1500
88 Goldwing 1500
85 Goldwing 1200
84 Gold wing 1200
80 Goldwing 1100
79 Yamaha XT500
78 Honda 750K
« Reply #13 on: May 01, 2017, 04:30:32 PM »
There are a few guys that have done it. Here is one post of it.
http://www.valkyrieforum.com/bbs/index.php/topic,66082.0.html
RainMaker
Arlington, TX
« Reply #14 on: May 02, 2017, 10:19:48 AM »
RckyMtnRider
I made a vacuum canister out of PVC as described and ran vacuum lines from #3 and #4 to it.  It's installed on top of the radio in the fairing (I/S).  Works great.  If I were replacing it, I'd probably look hard at the Rostra.
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #15 on: May 03, 2017, 02:03:51 AM »
I would not install the Audiovox ccs100. I have built several and everyone of them fail over a period of time. I just installed the Rostra cruise control on my interstate that is the only way to go. No Vacuum to deal with. You can buy the rostra off ebay new for 229.00 for the kit with everything that you will need.
http://www.ebay.com/itm/Rostra-250-1223-Universal-Cruise-Control-Kit-with-250-3592-Dash-Mount-Control-/252417996672?hash=item3ac548f780:g:-SYAAOSwfZ1WaYVb
« Last Edit: May 03, 2017, 02:11:14 AM by Attic Rat » Logged
N0tac0p
« Reply #16 on: May 03, 2017, 07:35:20 AM »
@ attic rat
is it fairly straight forward to install?  and where'd you put the actuator (can't tell the size by the pic, but looks huge
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #17 on: May 03, 2017, 07:54:57 AM »
I mount everything inside the fairing
« Last Edit: May 03, 2017, 07:56:35 AM by Attic Rat » Logged
« Reply #18 on: May 03, 2017, 04:42:56 PM »
Well I already bought it, so in it will go.
What is it that fails on the Audiovox?
Firefighter
Harlingen, Texas
« Reply #19 on: May 03, 2017, 05:01:43 PM »
Like I already said, mine has been flawless for five years, and I use it always. Thought I had a problem once and cleaned the valves as someone posted on this site (a how to), but it turned out to be my front brake switch.
1978 Honda 750
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #20 on: May 03, 2017, 05:08:58 PM »
The servo is what fails
