February 13, 2026, 10:25:33 AM *
Author Topic: Permanent SuperValk Conversion - Help  (Read 1760 times)
Rider89
VERY Northern Illinois
« on: April 30, 2017, 09:13:29 AM »
First...I know if I remove the trunk permanently then its not a SuperValk anymore.
Having said that, I'm a solo rider, LOVE my I/S, but not really a fan nor do I need the trunk...so I'll probably take it off permanently.
If I want to get a passenger backrest and pad (for the times that I'm more social) are there any mods that I need to make to be able to take it on/off...much like I do the trunk now?
Markus
Markus
Rider89
da prez
Wilmot Wi
« Reply #1 on: April 30, 2017, 09:47:15 AM »
   Marcus , have we met. I am in N/E Illinois .
                                                           da prez
« Reply #2 on: April 30, 2017, 10:27:34 AM »
Someone recently posted the same question.
Replace the IS fender rails with ones from a std/tourer, and get the hardware to mount a back rest. Or nothing.
The IS seat is one piece. Get a std/tourer set, and remove the passenger seat, and ride.
Rider89
« Reply #3 on: April 30, 2017, 10:31:21 AM »
                                                           da prez
Not sure. I didn't ride last year due to surgeries, but I've been out every day above 55 degrees this year. I'm up in Fox Lake
Markus
Rider89
Rider89
« Reply #4 on: April 30, 2017, 10:33:24 AM »
Thanks. I've got a set up Ultimates (3 piece) for the I/S. I'll start looking for the rails.  cooldude
Markus
Rider89
Challenger
Posts: leet
« Reply #5 on: April 30, 2017, 04:38:10 PM »
Super Valk with Cobra sissy bar for 1500 Intruder installed on trunk mount studs. When pillion and sissy bar are removed, I just put the chrome acorn nuts and washers back on the studs. Works for me!  cooldude
mark81
Cincinnati Ohio
« Reply #6 on: April 30, 2017, 07:35:26 PM »
I'll even trade you your interstate trunk and rails for my standard rails, luggage rack, sissy bar, and solo bar Delivery and installation included.
« Last Edit: April 30, 2017, 07:41:36 PM by mark81 » Logged
1997 Honda Valkyrie
1981 Honda CB750 Custom
Bagger John - #3785
« Reply #7 on: May 02, 2017, 09:52:22 AM »
What sort of modifications are/were required to make these fit?
Compare the width of the lower section of the Cobra sissy bar to an OEM Honda bar - are the dimensions the same? In other words: Can I find a set of Cobra side plates and use my stock Tourer sissy bar/backrest pad/rack on them?
Relax
Power & elegance...just like the Valk
Oslo, Norway
« Reply #8 on: May 02, 2017, 11:43:21 AM »
nuff sed ....
« Reply #9 on: May 02, 2017, 12:19:13 PM »
nuff sed ....
Wow !!! That is stunning.  cooldude
da prez
Wilmot Wi
« Reply #10 on: May 03, 2017, 05:34:38 AM »
 Marcus , I am in a Cary suburb. (that means high taxes) . You are about 20 minutes from me. Wooffred is near by and sets up a lot of rides. I also have a place in Island Lake.
                                         da prez
BuckeyeDude
Delaware, OHIO
« Reply #11 on: May 08, 2017, 07:50:43 PM »
I simply had a bracket made that fit the same trunk brackets.  Cost me about $300 with powder coat.  Also, had speakers installed in the saddle bags, but kept connections so I can put my trunk back on and use those speakers as well as the lights.
I thought about making it permanent, but I'm the type that, as soon as I do it, I'll find a reason to need the trunk.  Actually going to put bigger speakers and a subwoofer in the trunk for major jam sessions  Evil Evil Evil cooldude cooldude cooldude
bzane
« Reply #12 on: May 11, 2017, 07:01:41 PM »
Relax: Wow! That is beyond words.
Totally shames the Fury, but that's a low bar.
Totally shames any boomer/chopper I've ever seen.
tybme
1999 Valkyrie I/S
Topeka KS
« Reply #13 on: June 29, 2017, 09:05:19 AM »
Sorry I am late to the party.
If I understand you correctly you were able to use Cobra's Intruder sissy bar set up with your interstate trunk mount. Is this right? It bolts right up with no modification needed?
**** looking closer it appears you needed to drill new rear bolt holes. Am I seeing that correctly?
« Last Edit: June 29, 2017, 09:15:32 AM by tybme » Logged
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways. totally worn out, shouting, "Holy ****... What a Ride!"
