April 30, 2026, 05:38:07 AM *
Author Topic: Hey Robert! Tire question man....  (Read 2580 times)
AdrianR
Far North Chicago Burbs'
« on: May 01, 2017, 04:40:46 PM »
I seem to remember you posting some kind of cool matrix show dimensional differences between tire sizes.  I cannot find the thread.
When I get a new set of Michelins, I am thinking of getting a 190 55R instead of the 180....Will the 190 size be taller or shallower? (sidewalls)
Thanks! cooldude
« Reply #1 on: May 01, 2017, 05:58:03 PM »
Here you go my friend
https://www.tacomaworld.com/tirecalc?tires=130-60r19-120-70r19
Just input the tire sizes and let it do the calculations and comparisons.
 The sidewall height will be higher which is why I didn't want to change the size. How come you are considering this since there are so many tires in the oem size already?
  The rear tire never concerned me since its a standard size with many options available. I hate the front though since the the size limits the tire selection. It really didn't have to be this way since if you do a comparison to the wing tire the outside circumference is basically the same. So if they had gone for smaller rim size we could have had a much wider selection of tires.
You know you could go for the Pirelli with the stock rear size and the 120/70/19 front. It got some really high ratings by those who had the Michelin's before.
« Last Edit: May 01, 2017, 06:39:03 PM by Robert » Logged
Dragunslayer
"AN APEX IS A TERRIBLE THING TO WASTE"
Robertsville, MO
« Reply #2 on: May 02, 2017, 09:00:50 PM »
Thanks! cooldude
Adrian,
    While you will most likely be happier that the 190/55-17 will be about the same width in appearance as the stock Dunlop, you will not be happy with mileage returns.
Since the tire is actually intended for a 6 inch rim you will find that the tire is more bloated or high in the center. This will result in the bike turning in normal and then having a feeling of falling into the turn at a certain lean point.
I cannot confirm as of yet, but the mileage on mine is most likely going to be a little lower than the 180/55-17 I ran before this. Again this will be due to the high center tread or bloated appearance oif the tire.
This has been my observations so far.
Kevin Reinhold AKA Dragunslayer
Robertsville, Mo
1999 Honda Valkyrie Tourer
2015 Kawasaki Concours 14
2016 Suzuki GSXS-1000F
« Reply #3 on: May 03, 2017, 02:06:10 AM »
Adrian,
I was wondering how this was working for you, thanks for the update.
st2sam
N.E. Pennsylvania
« Reply #4 on: May 03, 2017, 05:08:38 AM »
Adrian,
+1
I thought about a 190/55 but after research decided against it.
Although it will mount on a 5-1/2" wide rim a 6" is the preferred size.
My thoughts were, what you described my be the results.  Thanks again for sharing yours. (results)
I'm shopping for a rear tire now, have a newer PR4 Trail on the front so I'll go with the PR4 rear again. I get about 4,000 mi. before wear bars show on the Mich..
I'm thinking next set I'll try the Pirelli's.  (180/55)
« Reply #5 on: May 03, 2017, 09:07:42 AM »
+1
Not for sure but try the PR4 Gt not just the PR4  the GT is a stronger tire and may get you more mileage.
st2sam
N.E. Pennsylvania
« Reply #6 on: May 03, 2017, 01:52:28 PM »
+1
About $15.00 more for the GT. Maybe I'll give it a try.  cooldude
AdrianR
« Reply #7 on: May 03, 2017, 01:54:21 PM »
Thanks! cooldude
Adrian,
Thanks, seems logical.
Dragunslayer
Robertsville, MO
« Reply #8 on: May 03, 2017, 06:25:42 PM »
+1
All my Michelins have been of the GT variety. I got 4K out of the 180/55-17 and am currently at a little shy of 3k and will be pushing it to get the same mileage out of the 190/55-17 I have on the bike now.
I have not decided which tire I will try next but it may be a Dunlop Roadsmart 3 or a Pirelli.
Robertsville, Mo
