February 13, 2026, 07:06:11 AM *
Author Topic: Helmet Lock  (Read 1986 times)
Itinifni
Boston
« on: May 19, 2017, 03:50:57 PM »
Like most everyone here I find my Valk to be close to a perfect bike, at least for me. There are a few things though that I can't believe Honda omitted from the bike, in particular a reasonable helmet lock, self-canceling turn signals and a center stand. I thought I'd show my solution to the helmet lock issue (for standard and tourer owners).
I looked at the available options on various bike sites as well as eBay/Amazon. The Kury bar end set up looks interesting but I don't have the grips and it was not really what I was looking for. Most of the generic locks look like junk and I really don't want my helmet hanging off the side of the case guard.
I do have a Master cable lock and while solid it's not that convenient, I want to get off the bike, lock my helmet and walk away. Not take off the seat or dig around for a cable, yea, I'm lazy.
I started looking on Pinwall at various factory helmet locks and found the VMax OEM unit looked interesting so I bough two, one from an 03 the other an 07. They are identical.
They didn't come with keys and the offset is opposite my Valk key (though I think I've read later Valks use a different key). At any rate my plan was to key the locks alike and hand cut a key.
First step is to disassemble the locks by removing the plate on the underside.
Use a screwdriver to push the pawl out of the way and release the helmet hook.
Remove the spring and pawl with a pair of needle nose plyers.
Use a screwdriver to push the retainer into the lock cylinder and the cylinder will slide out of the body.
I removed the tumblers and springs and reassembled the helmet lock.
I installed the locks on each side of my rack by replacing the upper rack/back rest bolt with longer stainless steel Philips head screws. I had to drill one hole per side for the helmet lock locator pin.
Ease of use and placement is exactly what I was looking for.
The locks function normally as far as latching and requiring a turn of the cylinder to open except that right now any key will work, or a screwdriver for that matter. Anyone walking by admiring my helmet doesn't know that though.
I still may go through my box of lock tumblers and see if I have a few pairs of matched tumblers to key both locks alike so I could have one key for both but then I'd have to carry another key.
Then again, I may just leave them as they are and use the cable the few times I really want my helmet secure, like I said, I'm lazy.
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
97 Valkyrie Std. (May surpass the GL1100 as the best bike I've ever owned, I'll update in 50k miles)
« Reply #1 on: May 19, 2017, 05:18:18 PM »
BigBikeParts makes a clutch pivot replacement bolt that doubles as a lock for D rings. About $12. Takes 5 seconds to lock my helmet.
Harryc
Sebastian, Fl
« Reply #2 on: May 20, 2017, 05:56:51 AM »
Sandy, assume you are talking about this item? http://www.bigbikeparts.com/templates/product.aspx?ProductGuid=53-443&GroupGuid=29
Do you use a small padlock with it? Is it 6mm or 10mm for our bikes?
« Last Edit: May 20, 2017, 06:01:02 AM by Harryc » Logged
« Reply #3 on: May 20, 2017, 06:36:17 AM »
The version I have came with a small padlock. I've bought two of these over the years. I wasn't aware of two sizes. The site you show says 10mm and then says it's for a Harley. HMMM Try looking on Amazon for a helmet lock. I got mine at a local service shop.
« Reply #4 on: May 20, 2017, 07:22:29 AM »
I used the clutch pivot replacement for years, furnished my own lock. Works great, cheap(my motto), effective. Just remember to hang it with the open side down if it's cloudy. I once came back to my bike and had a refreshing lining for the next couple days....helmet was full of water due to a short summer shower.  Grin
Harryc
Sebastian, Fl
« Reply #5 on: May 20, 2017, 07:52:24 AM »
Thanks. I am being lazy. I'll take one out and measure it. It a good excuse to lube the pivot anyway.
sdv003
Prescott Valley, AZ
« Reply #6 on: May 20, 2017, 11:50:31 AM »
I think the one for our bikes might be
2-354 - 6MM HELMET HOLDER STUD
They call it out for "most metric bikes"
« Reply #7 on: May 20, 2017, 12:07:16 PM »
And then someone who actually would take your helmet will just cut the chin strap.
Savago
Brentwood - CA
« Reply #8 on: May 20, 2017, 01:14:32 PM »
Nice post! Thanks for sharing the photos/info of how you did it.
o/
Itinifni
Boston
« Reply #9 on: May 20, 2017, 03:15:53 PM »
I came across the clutch pivot stud on BigBikeParts but didn't see an easy way to lock it. I also didn't like the fact that the stud in the photo is not shouldered.
73? CT70
79 CB750K
82 GL1100
94 CBR1000F
Kid
Kid
« Reply #10 on: May 20, 2017, 03:33:36 PM »
Kuryakyn makes a helmet lock for the end of ISO grips.  Kind of expensive.
https://www.ebay.com/p/?iid=330941584738&&&chn=ps
One of my bikes came with one.  I rarely use it (or any lock), unless where I stop has sketchy looking humans around.  90% of the time I stick it on my Dr's backrest... or take it inside with me.
My helmet runs $125...... not $600 +/-.
