February 13, 2026, 08:32:39 AM *
Author Topic: i5 Levers  (Read 979 times)
h13man
Indiana NW Central Flatlands
« on: May 27, 2017, 06:45:55 PM »
I purchased a set of these adjustable levers. Clutch side worked fine but the lever was made too thick to use on the brake side because of the throttle cable housings. Not enough room regardless of adjustments.
i5® Adjustable Chrome Brake & Clutch Levers for Honda Shadow VT 1100 Valkyrie VTX 1800
https://images-na.ssl-images-amazon.com/images/I/61%2BiccW3MoL.jpg
« Reply #1 on: May 27, 2017, 11:34:30 PM »
The interstate throttle housing exits at the bottom, not the front.
I do not know if they work on standards and tourers, but I think they do.
Not sure if #5 is the part you need, if usable.
http://www.procaliber.com/oemparts/a/hon/506c2f6df870023420a31b4c/switch-cable
If the levers you bought say they fit Valkyrie, and they don't, I'd try to return them for refund, even if they have tool marks, and replace with a set of adjustable for 1800GL, which only need a small piece cut off.
http://forums.delphiforums.com/valkyrie/messages/?msg=13360.1
http://wingstuff.com/products/36601-adjustable-wide-brake-clutch-levers-for-gl1800
Or Kuryakyn adjustables for GL 1800
Or Kuryakyn wide chrome non adjustable for Valkyrie. (reach shorter than stock, and great)
« Last Edit: May 27, 2017, 11:36:38 PM by Jess from VA » Logged
h13man
« Reply #2 on: May 28, 2017, 05:48:30 AM »
Standards exit front of housing thus the issue. Vendor (Amazon) has no problem with return. Already have Kury wide levers.
