April 30, 2026, 03:05:31 AM *
Author Topic: Torque Loops with New Torque Master Pipes installed on my F6C 2014  (Read 4033 times)
rudymsmith
mobile, al.
« on: June 11, 2017, 12:41:42 PM »
Just got everything installed and back together - at 1800 miles I found lots and lots of loose nuts in bolts around the bike - YIKES!
Torque loopz and Torque Master pipes Install didn't require as much swearing as when I installed on my F6B. I had to remove the left side hard case because the bracket wasn't lining up just right. Make sure you do a dry run before you start cutting - measure three times and cut ONCE. I used a little exhaust sealer for good measure.
I did the "adaptive" reset by: starting the Valkyrie with no throttle and running it till the fans cycled on AND off - then I shut it down; and let it cool off. I did a restart about an hour later and took it for a long highway adaptive ride. The sound is not too loud, no drone just sweet rumble. I can't say I felt any power gains - yet. Rode her like a new toy.
Be careful what you wish for.
goldstar903
« Reply #1 on: June 11, 2017, 01:24:24 PM »
Cool! Do you think it's worth the money sound wise. I know that it's a modest HP (~3) increase, but I imagine that a re-flash should get you more.  Undecided
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
rudymsmith
mobile, al.
« Reply #2 on: June 11, 2017, 03:01:27 PM »
I like the sound - a little more authority without being obnoxious. None of the drone.
I will hold off on the guhl reflash until warranty runs out.  police
« Reply #3 on: June 11, 2017, 05:29:39 PM »
I am curious about the adaptive reset, are you sure that is the way to do it?
lazos valk
Western Ma
« Reply #4 on: June 11, 2017, 05:39:57 PM »
Nice. Any pics or sound bites.
rudymsmith
mobile, al.
« Reply #5 on: June 12, 2017, 07:53:02 AM »
I repeated the procedure as I learned on the F6B forum - and it works at least as far as I can tell.
Also the cold hesitation seems to be gone.
GA VALK
« Reply #6 on: June 15, 2017, 04:47:18 PM »
How many baffles do you have in?
rudymsmith
mobile, al.
« Reply #7 on: June 17, 2017, 10:49:54 AM »
I do not have any baffles that i am aware of... just the torque loops and the torque master slip ons. Cats gone.
GA VALK
« Reply #8 on: June 19, 2017, 02:59:45 PM »
And the sound is great!
bscrive
Ottawa, Ontario
« Reply #9 on: June 19, 2017, 05:25:04 PM »
WE NEED PICS!!!!!
