February 13, 2026, 09:00:50 AM *
Author Topic: Need new engine  (Read 1449 times)
Sergiy Kapelynka
Ireland
« on: June 14, 2017, 03:05:13 PM »
Hi everybody, I am looking for a new engine for my motorbike. I found one on ebay but there is a problem with purchase and postage. Who can help?
http://www.ebay.com/itm/263024435665?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
« Reply #1 on: June 14, 2017, 03:39:30 PM »
It doesn't sound like you have a technical problem, but a logistic one.  You haven't let us know what your specific problem is, so we can't suggest solutions.
« Reply #2 on: June 14, 2017, 04:03:59 PM »
remember if u want lower hwy RPMs get a '97-00 Goldwing GL1500 engine.
Sergiy Kapelynka
Ireland
« Reply #3 on: June 14, 2017, 04:23:30 PM »
I want to find a new engine for my Valkyrie.
« Reply #4 on: June 14, 2017, 04:29:00 PM »
Where are you located ?
« Reply #5 on: June 14, 2017, 04:36:52 PM »
I think the ? is But Why? Most just fix their engine if it ever has problems.
« Reply #6 on: June 14, 2017, 04:58:54 PM »
What is wrong with the current one? I mean this is a tech board. Tell us your problems and we will give you several fixes if there is a fix. Of course there is a fix, it is a mechanical device. Location would be a big help  cooldude
firea100
East China Mi.
« Reply #7 on: June 16, 2017, 01:55:02 PM »
...The comment on the lower highway rpm's... is the goldwing trans geared differently? Can you please shed some light on this?
Thanks, Larry in East China Mi.
« Reply #8 on: June 16, 2017, 02:03:28 PM »
According to Fred Rau in motorcycle consumer news june 05 article. GL1500 3rd 1.272, 4th .964, 5th .758.
Valkyries 3rd 1.291, 4th 1.00, 5th .805. 1st and 2nd are the same.
early than '97 gear sets will not work, the GW shafts are smaller from my understanding and other posts from a few yrs ago. The parts fiches seem to bear this out.
Goldwing gears have always been straight cut. Don't know about the GL1800.
http://www.goldwingfacts.com/forums/forum1/101096.html
http://www.valkyrieforum.com/bbs/index.php/topic,27706.0.html
from the June '05 issue of motorcycle consumer news, by Fred Rau. He was the editor of Wing World magazine in '87, the news letter of the largest Gold Wing organization, the Gold Wing Road Riders Association (GWRRA), and now contributes to MCN.
"in '97 the GW recieved a fairly major upgrade that was, oddly enough not heralded by Honda. Honda quietly lifted the Valkyrie's main bearings, pistons, piston rings, con-rod bolts and valve springs into the '97 Wing, along with the smoother-shifting Valkyrie gearbox and the entire final drive unit. In addition, the clutch was strengthened, also."
Also from the article, 1) '88 through '94, 4th and 5th gear wear out at around 100k miles, gears were upgraded in '95 and newer. Also, shift forks wear out from riders resting their toe on the shift lever while riding. their experts warned that the use of heel-toe shifters is also responsible for shift fork damage, as your heal puts much more force on the shifter than your toe would. 2) speedo cable should be lubed every front tire change other wise they break at 100k miles. 3) final drive splines, maintenance should be done IAW honda service bulletin 97991-MAH-305.
http://www.valkyrieforum.com/bbs/index.php/topic,29276.0.html
