February 13, 2026, 10:25:14 AM *
Author Topic: CB Antenna on Interstate  (Read 1200 times)
Truenorth
« on: June 15, 2017, 05:55:38 AM »
I just bought the mount for the antenna from a GL1200. Does anyone have the specifics on what is needed to make it fit the Interstate. How much do I cut off? Once I open up the bottom will it just fit over the bar under the trunk? Thanks, Ed
Ramie
2001 I/S St. Michael MN
« Reply #1 on: June 15, 2017, 07:06:01 AM »
Are you referring to the mounting bar shown as shown here?
https://www.mototourinc.com/type-iii-radio/cb-antenna-for-goldwing-gl1200
Truenorth
« Reply #2 on: June 15, 2017, 07:35:38 AM »
Yes, that is the one I bought and I'm told it fits on the Interstate but needs a few mods done to it. Looking for measurements or diagram or ?? . I'd like to measure 3 times and cut once.
thanks
ridingron
Orlando
« Reply #3 on: June 15, 2017, 06:07:11 PM »
Now that kinda takes the fun out of it, doesn't it?   Grin
Bagger John - #3785
« Reply #4 on: June 16, 2017, 05:39:43 AM »
You want to mimic the clearance distance of your AM/FM antenna's mounting base to trunk. Measure that then lay the GL1200 part against the rear trunk mounting stay and find the right spot. Then, mark the end of the 'Wing mounting arm where you'll need to remove material (and if memory serves, you will).
Truenorth
« Reply #5 on: June 20, 2017, 05:33:30 AM »
Thanks much. Ed
