February 13, 2026, 09:00:47 AM *
Author Topic: Axle pinch bolts  (Read 1490 times)
VMODON
« on: June 15, 2017, 08:26:56 PM »
16 ft lbs.?? can this be right. its just barely snug at that setting.
da prez
Wilmot Wi
« Reply #1 on: June 15, 2017, 09:06:18 PM »
 That is correct. Just redid my fork seals and I also have the Honda bible . The bolts are the equal to a quarter inch. The also thread into aluminum. Use a torque wrench and follow the tightening sequence.
                                            da prez
« Reply #2 on: June 17, 2017, 07:42:14 AM »
Blue Loctite can be your friend.
Daniel Meyer
The State of confusion.
« Reply #3 on: June 17, 2017, 05:51:58 PM »
Also...do 'em in stages. There's a pair together...they effect each other. (loosen in stages too...once one breaks loose I often tighten it a bit just to make loosening the other easier).
CUAgain,
Daniel Meyer
